Question about Honeywell Heating & Cooling
I just finished changing the 3 AAA batteries and now the themostat does not work so... how do reset my honeywell digital thermostat? to get it to work again
    New Friend:
  • 11 Answers
Found this for you:
Insert the batteries backward, so that the negative pole lines up with the positive terminal. Leave the batteries placed backward for at least five seconds.
Remove the batteries and put them back in the correct way, then close the battery door. The display will turn on. The thermostat is now reset
Posted on May 17, 2017
My upstairs themostats is not working,but my downstairs thermostat is working, how can I fix this?
Normally thermostats does not contain battery. Some time cleaning with contact cleaner will help, or replace with same type.
Jan 08, 2015 | Honeywell Heating & Cooling
Need help understanding how to wire a new programmeable thermostat. I currently have a White Rodgers 1F73 model (non-programmeable) connected. I am confused with the instructions on how to connect the...
the black wire is your common wire, you need to program your thermostat, in the advance mode, to tell the t-stat if your heat pump reversing valve is energized on cooling or heating, is the orange wire connected to your t-stat.= w2/o/b
Dec 20, 2014 | Honeywell Heating & Cooling
Changing batteries I Honeywell thermopro 3
Any Honeywell thermostats I have come across you slightly tug on bottom of thermostat which disengages it from the wall and lift up. Batteries are then exposed. Replace with new and reverse take-off procedure to remount. If I remember correctly these do have a small battery backup to save your initial settings so you do not have to reset time and program. Can you tell me the complete model number of thermostat or send a picture of it?
Dec 30, 2013 | Honeywell Heating & Cooling
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
The thermostat for the main zone in my house (honeywell model RTH5100B1017) is battery powered and it blinked change the battery for a couple of daye and then went blank. I have changed the batteries twice...
  • Check any batteries and replace if needed. Ensure that you use only AA alkaline, nonrechargeable batteries.
  • 2 Check for oxidation buildup on battery contacts. Use electrical contact cleaner and carefully clean the battery contacts of any oxidation buildup.
  • 3 Reset the system switch.
  • Read more: How to Troubleshoot Honeywell Thermostats '
    Dec 09, 2010 | Heating & Cooling
    I want to install honeywell RTH 221 thermostat.Thr thermostat operate 2 AAA batteries. the thermostat remote the heating system selonoid valfs. They works with 220 volts.My question is can I connect the...
    If your old stat operated on high voltage ( anything over 24 volts) then the answer is no. However by adding some relays and a transformer you can use that stat.
    Jan 15, 2010 | Honeywell Programmable Thermostat Heater
    Honeywell CT200A thermostat battery will not recharge.
    Yes the battery charge circuit is burned out, you might as well replace the thermostat, parts will not be made to fix it unless it is still under warranty.
    Jan 27, 2009 | Honeywell Programmable Thermostat Heater
    Heating & Cooling Logo
    50 people viewed this question
    Top Honeywell Heating & Cooling Experts
    Bill Long
    Paul Carew
    vance jones
    Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
