Question about Kenmore Washing Machines
I have a Kenmore Series 90 washer that no longer can get hot water when selected. I changed the water inlet valve and have the same issue.
I checked hoses for flow when changing valve. Both were good. Any thoughts. Do you think I my have gotten a bad new valve? Replaced valve with a new 285805 valve. Any help would be appreciated.
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
rpbuice
  • 161 Answers
SOURCE: Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Posted on Jan 08, 2009
  • 864 Answers
SOURCE: kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
Posted on May 31, 2009
  • 53 Answers
SOURCE: Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Posted on Jul 09, 2009
Joe Onley
  • 363 Answers
SOURCE: Kenmore washer 90 series will not fill up with water
You can shut off the water, then remove the hoses to see if the screens on the fill valve are gunked up. This is much easier to do than to replace the valve. I think you'll have sucess on that route :)
Posted on Aug 26, 2009
Kenmore washer 70 series(top loading) only dispenses hot water. Have changed the inlet valve-no help.What is my next step?
The water temperature selection switch would be what I would check next.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 30, 2011 | Kenmore Washing Machines
Kenmore 90 series washer will not dispense hot water
shut off the house vater valve,remove the hot water hose,stick it in the tub or bucket,turn the water on,if water comes out ok chnage out the water valve on the washer.
Feb 22, 2011 | Kenmore Washing Machines
Hello, i have a kenmore 90 series washer. Just recently, it has started to fill very slowly only on the cold water cycle and the temperature knob isn't working right, only cycles between cold and warm, no...
The first thing to check are the screens at the inlet of your washer hoses. Turn off water supply to washer then remove the hoses at the washer side,then look into the inlet valves and you should see one screen in each hose inlet,carefully pry out the screens and clean in the sink then reinstall screens and the hoses and check for leaks.. this should speed up your cold water fill,you may still have to replace the control switch or solenoind valve assy to get your hot water..Easy job hope this helps GOOD LUCK
Sep 08, 2010 | Washing Machines
Kenmore series washer- losing water pressure
it does sound like you have a inlet valve going bad.
i assume this happens on both the hot and cold water sides. if not try and switch hose and see what happens if the water pressure drops then replace the water valve.
Feb 06, 2010 | Washing Machines
Kenmore HD Series 80 - hot water trickles in.
Pull the two screws at the bottom corners of the control panel. Pivot the panel up. Lever the two metal keepers underneath forward and up to remove them. Tilt the housing forward and pull it toward you to remove it. Make sure you unhook the lid switch wiring plug before you remove the housing.
Water inlet valve should all be one piece for hot and cold.
Nov 15, 2009 | Kenmore 26882 Top Load Washer
Washer keeps filling up with hot water
Hi
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore Washing Machines
Aug 09, 2009 | Kenmore Washing Machines
Jul 08, 2009 | Kenmore Washing Machines
Kenmore 90 series cold water trickle
Hi, If there is good pressure to the valve and the screens inside the valve are clean, you will need to replace the inlet valve.
Please let me know if I can assist you further with part# or how to replace the valve.
Thanks
Vic
May 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
