Question about Electric Electrical Supplies
Spark plug gap for Chicago electric generator 3500watt
  • 37 Answers
SOURCE: CONTACT BREAKER GAP FOR HONDA ES3500 GENERATOR
Recommended spark plug is BPR5ES (NGK) W16EPR-U(Denso)
Spark plug gap is 0.7-0.8mm (.028-.031in.)
Air Gap for your ignition coil is .4+-,02 mm(0.016+-0.008in.)
Posted on Nov 22, 2009
kel1guy2002
  • 3740 Answers
SOURCE: tappet clearance and spark plug gap on 5.5 hp ohv
I have a Robin but they all are pretty much the same for plug gap and tappets. I worked in a lawnmower small engine repair shop for many years in San Diego
I set them all the same and never had one return. I just did mine a couple of months ago and hand lapped the intake and exhaust valve seats. Starts first time everytime like the 7.5 year old unit is new!!!
Plug gap 0.19
Tappets
Intake .005 cold
Exhaust .006 cold.
Posted on Jan 25, 2010
SOURCE: i need an owners manual for a chicago electric generator
ago electric Generator Manuals\r\n
The Harbor Freight web site has PDFs for most of these generators. Go to.
http://manuals.harborfreight.com/manuals/XX000-XX999/XXXXX.pdf
Replace the first two XXs with the first two digits of the model number, and the last XXXXX with the model number.
For example, the manual for model 65414 would be on the following page.
http://manuals.harborfreight.com/manuals/65000-65999/65414.pdf
Posted on Jul 06, 2010
  • 130 Answers
SOURCE: i have a problem with
did you blow out old gas from gas line going to carb? if this generator set up over the winter with no use, it probably has water condensation in the gas tank which has gotten into the gas line and carb. If you didnt do it already, blow undo the gas line off the tank and use compressed air (or by mouth) to blow out all the fule out of the line and carb. If you did not drain the old gas out before adding new gas, there still may be water in the tank and line. Try this and see if it fixes it. Give it time for the new gas to get through the line to the carb. To avoid this, keep the fuel tank full especially over the winter and you will not get any water condensation.
Posted on Mar 28, 2011
kel1guy2002
  • 3740 Answers
SOURCE: Just bought a Homelite 2500
Lets cut to the chase here.
I know the engine replacement part number is: 309591038..... BUT, I do not know what engine this is. There is an ENGINE number some where on this engine that I need to help you. Usually it is not to far from the oil dip stick area on the base of the engine. If you would plese pass me the engine number so I can help you.
Kellu
Posted on May 07, 2011
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
Steele 9000 watt generator won't start
Hi Derrick
I assume you can turn over the engine, and the engine has run previously?
Check for spark, -take off the plug lead and connect an old spark plug to the ignition lead open the gap up to about 5/16 inch . Tie the thread of the spark plug to the engine to hold it and earth it with a bit of soft wire. Wind over the engine you should get a nice fat blue spark. If you get a nice spark do you can eliminate ignition issues. This just leaves fuel. You can then focus on this.
Jacko
Apr 13, 2014 | Steele Products 9000 Watt Portable...
Onan 5.5 Hgjab Generator Manual
Gap is 0.025" plug is a NGKR BPR4EY
Cummins part # 167-1638
Jul 26, 2013 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
What is the Coleman Powermate 5000W Generator spark plug gap
Powermate 435001 w Subaru EX30 spark plug gap is between ..006 - .007 according to manual.
Sep 22, 2012 | Coleman Powermate Subaru 5000W Portable...
Why won't my Homelite 720 watt Generator start?
hi am elie hawzi i have generator 720wat homeliet had to run wer can i put 2 storc oil in my generator pleas do you have any adia haw can i leave the generator run stridaway thanks for fixya
Jun 28, 2012 | Electrical Supplies
Gas in oil
Maybe. Put a pan under the genset, drain the oil, leave the drain plug out until you figure out why the carburetor was allowing too much fuel to flow (likely a stuck float). When you think that you have it figured out, replace the drain plug, add fresh oil, remove spark plug, and perform a compression check to see if the rings are worth it. If compression is low, then you can decide if it is worth your time and expense to repair the engine.
If memory serves, Harbor Freight sells compatible, if not identical, engines that will fit this generator.
Mar 16, 2010 | Coleman Powermate 7,000 Watt 13 Hp...
Tappet clearance and spark plug gap on 5.5 hp ohv engine, i have a generator which runs on natural gas made by china i just want to know the gap of tappet and the spark plug gap
Plug gap 0.19
Tappets
Intake .005 cold
Exhaust .006 cold.
Jan 25, 2010 | Watts Onan Portable Generator - 4000 ,...
Where can i find fuel valve for a 3500watt generator by wen besides xmc products
should be on the tank where the fuel line comes out. May be another near the choke adjustment
Dec 04, 2009 | Watts Onan Portable Generator - 4000 ,...
CONTACT BREAKER GAP FOR HONDA ES3500 GENERATOR SPARK PLUG GAP.
Nov 16, 2009 | Electrical Supplies
Electrical Supplies Logo
44 people viewed this question
Top Electrical Supplies Experts
ashburton
Steve
Mike Carew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
