Question about Refrigerators
Error Mess. Er IF
I have an Sears Kenmore Elite Trio Refridgerator. Error Message - Er IF. Ice maker not working nor will it despense water.
    Champion:
  • 363 Answers
Icemaker fan
Posted on Jul 26, 2009
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
Kenmore Elite trio Error 15
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We have the kenmore elite trio bottom freezer refrigerator model 795.7756 - we have error message ER IF, we know the ice maker will not come on and have tried resetting it. How can we get the icemaker to...
Sep 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Refrigerator error er dh
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Sep 21, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Error message
Hello gravyblast.
Welcome to Fixya.
You said, your Kenmore Elite Trio, model 795.7756 or 7757 has an error message simply reading ER IF. No pressing of buttons, or combination thereof changes anything. Also, the ice maker has stopped working although it is turned on.
Can anyone help?
I cannot pull the refrigerator out to unplug and reboot it, thus I don't know what to do.
Try tripping the breaker off for 5 minutes and then see if this method resets the system?
Do not turn it back on for at least tree minutes. That's why I said, Five!!!
Lets see how it resets while I look your fridge up.
Write back. Huuum
7:11 pm eastern standard time . I'm here!
Sep 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Error code Er IF is on the display and noone from sears can tell me what it is, does anyone know?
ER IF means error icing fan, the problem is with a little board that is behind the water dispenser. Change this board and you will be in business.
sgt 48
Jun 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio
pull the kickplate or look on the back of the unit in the compressor comparment some where on that unit is a tech sheet that will explain that code i dont have access to kenmore tech data as sears tends to keep a pretty good lid on it but if you find the sheet and reply i can help
Jan 19, 2008 | Refrigerators
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
