I have a Hisense XQB70-XC14 washing machine as soon as i press power on. The error cose E2 keep coming. What can I do here please?
  • 43 Answers
SOURCE: Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Posted on Nov 11, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
SOURCE: E2 error on homemaker washing machine.
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Posted on Nov 08, 2009
richroth
  • 9472 Answers
SOURCE: hi we have daewoo washing machine coming error
Error code E2 is overflow problem, possibly related to the pressure switch.
If the pump runs continuously then try checking that the drain hose is not blocked or that the waste outlet is not blocked.
If that checks out OK then the pressure switch is stuck in the high level.
Take the capillary hose off from the pressure switch and blow down it to remove any residue stuck in the pipe.
Posted on Jan 14, 2011
  • 3 Answers
SOURCE: C2 error
aeg lavamar error c2
Posted on Feb 04, 2011
Aw1171ubb error code E2
This error referes to the door not being closed or locked. Please double check the door and replace the door latch if necessary.
Oct 25, 2015 | Washing Machines
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
Washing machine XQB90-701CLPS KEEP COMING E2
The error code E2 points at a faulty lid switch. Check that the lid is well closed, check the lock mechanism. The lid switch can be tested by running a cycle with its contacts jumped.
Jun 24, 2011 | Washing Machines
Sep 07, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Power cuts off
The machine beeps E2 all the time. Actually E2 error code means washer door is not closed properly. However washer door does close properly, but the machine still beeps with showing E2 error code. Please help solve this problem.
Many thanks,
Robert
Jul 04, 2008 | Haier XQB60-91AF Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
