Question about Health & Beauty
I need a wiring diagram for a cen-tech 60581 battery charger
4 Suggested Answers
SOURCE: Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Posted on May 30, 2009
  • 6 Answers
SOURCE: Both Battery clips have come off of Schumacher
You need to connect the battery cable wires to the battery in order for the charger to "turn on" the output. If the "reverse polarity" LED lights up, switch the wires. The RED clamp goes to the + battery terminal wire, BLACK goes to the other.
Posted on Sep 22, 2013
  • 12962 Answers
SOURCE: need owners manual for a Sears battery charger model# 934.71614
Check out the manufacturer web site for manual download. Not sure about the schematic - you might get lucky but do not hold your breath.
Posted on Nov 09, 2015
I'm charging my battery on my rv new. Artery but it was ran down because my break switch was bad and the light stayed on my new cen-tech charger light stays green and I hear a clicking
Disconnect any wiring to the battery. Connect only the charger. Insure you have the charger connected to the proper polarity.
Does it continue to click? Does it not charge? If it won't charge for you, pull the battery and take it to a friendly service station or auto parts store that can test, and or charge it for you. It could be you discharged the battery all the way and damaged it. The normal safe zone is to never discharge below 50%. They might have to attempt a charge that takes up to 45 minutes. If the battery is over a couple years old I would opt to just replace it. I would never trust it and end up getting stranded somewhere.
Feb 13, 2017 | RVs
Wiring diagram for Energizer battery charger chvcm
You will never find one for these products. I have worked on many an you just can't find them good luck
Aug 23, 2016 | Energizer Rechargable Battery with Charger
I need battery charger cen-tech 69368 manual
Sorry to say, but Harbor Freight's parts list has no internal parts listed. So to fix it yourself, you may be able to find the little tiny diodes that usually go bad. They don't even have a wiring diagram in the owners manual.
Apr 03, 2014 | CEN-TECH Heavy Duty 6/12 Volt Battery...
Wiring diagram se-4020 battery charger
try this web site Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Can I operate a light on a 12v battery while it is being charged with a guest 2606A
yes, but a slightly depleted battery will take longer to reach full charge if the current is being drawn from it.... although if it's an LED light and efficient radio the current draw will be almost negligible or hardly enough to notice.
but why would you want to run mains electrical items from a battery that's plugged into the mains?
it's much more efficient to use mains electrical power for your devices until there's a power outage (this is where the inverter is really needed) or you need mains power in the middle of nowhere.
if you absolutely want to go down this route maybe an old UPS would come in handy, it will continue to output mains power in the event of a power outage.... just connect your battery in place of the old dead one (your 32Ah won't fit in the box, just use heavy cable) UPS boxes hold a 12v battery, it's a simple hack.
Nov 23, 2017 | Electronics - Others
When hooking up the cen-tech 60581 charger/starter the charge status light flips back and forth from green to red while the ammeter also flips back and forth. Is that what it is supposed to do until fully...
I don't think so, It did that on one of my lawn tractor batteries but not on the other lawn tractor or car battery, I suspect something is wrong with the battery.
Oct 01, 2013 | CEN-TECH Heavy Duty 6/12 Volt Battery...
Where can I down load an Cen -tech item 92375 5-1
Maybe Cen-tech can produce a manual or Harbor Freight might be able to help
Aug 09, 2013 | Measuring Tools & Sensors
Need manual or operating info for a cen-tech stud finder mdl 92375
Re: above answer. There is no button on this model. Now what?
Dec 22, 2012 | Measuring Tools & Sensors
Schematic for EV Warrior Electric Bike
I have a PDF of the schematic i drew for my bike. it is posted on the Yahoo power-assist group. look in the files section.
there is also a text file there that lists all of the wiring connectors and where each of the wires goes. as well as connection diagrams for the Curtis 1505 speed controller.
the charger circuit is very simple. the black and red wires from the charger port go straight to the batteries +24V and 0V terminals. the third white wire connects through a bullet connector to pin#7 (EPO wire) of the Curtis speed controller. this acts to turn off the motors while the batteries are being charged.
inside the charger male connector the pin for that 3rd white wire is shorted to ground. so when you plug the charger in the white wire is grounded thru the charger plug.
have fun. i really enjoyed my EV-Warriors while i could still ride them.
Mar 12, 2009 | Electric Bicycle Motor, Bike,electric...
Mar 11, 2009 | Ryobi Multi-Volt Battery Charger
Health & Beauty Logo
110 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
