Question about GPS
How do you delete an address from favourites in the nuvi 52?
2 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: Garmin Nuvi 255 - no separate feature to delete
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Posted on Jan 21, 2011
How to change language
Go favourites, select address, go edit, go delete
Aug 21, 2014 | Garmin nuvi 2797LMT 7" GPS Navigator -...
How do I delete items from recently found? How do
When you want to add a place to your favourites
  • Press WHERE TO
  • Enter the address
  • Instead of pressing GO press SAVE at the bottom of the screen or press VIEW MAP and then SAVE
It will be saved to your favourites folder and the keyboard will come up for you to give it a name.
You don't delete items from recently found. A certain number of items are kept there and overwritten as new ones replace older ones.
Jun 17, 2011 | Garmin nuvi 255W GPS Receiver
How do I delete one address at a time instead of all of them at once. Garmin Nuv260W
  • Press WHERE TO
  • Press FAVOURITES
  • Select the address to be deleted
  • Press EDIT
  • Press DELETE
Apr 10, 2011 | Garmin nuvi 260W GPS Receiver
I just bought a used garmin 255 and want to delete old addresses. how can I do it
  1. Press WHERE TO
  2. Press FAVOURITES
  3. Press the address you want to delete
Instead of pressing GO, at the bottom of the screen press EDIT
Then press DELETE and the address will be deleted.
Dec 10, 2010 | Garmin nuvi 255W GPS Receiver
How to write adress to Favorite in GPS Garmin nuvi 265 WT
  1. Press WHERE TO and type in the address
  2. Instead of pressing GO press SAVE which will be at the bottom of the screen
This will save the address to Favourites and give you an optoin to give it a name.
If you're at an address and you want to add it to favourites press the car on the map screen.
You'll get a message asking do you want to save your current location. Select YES and it will be saved to favourites.
Nov 21, 2010 | Garmin nuvi 265WT Car GPS Receiver
How to delete an address
Press Where to, press Favourites, select the address you want to delete, Press Edit and then Delete and then yes.
Aug 12, 2010 | Garmin nuvi 1300 Car GPS Receiver
How do I delete my favorites?
To delete all favourites:
With the satnav turned off press the bottom right corner of the screen with your finger and while pressing it turn it on.
Keep your finger pressing until a pop up message appears
Press yes and all user data will be erased. This will reset all original settings.
If you only want to delete some favourites:
Press Where to, press Favourites, select one to delete, press Edit, and press Delete.
This way you can delete them one at a time.
Aug 12, 2010 | Garmin nuvi 250W GPS Receiver
Want to delete addresses in recently found folder
Click on-Where to-Favourites-All Favourites-Click on the Address you want to delete,click on Edit,it then says Delete,touch Delete,it then asks you if you want to Delete or not,hope this helps you.
Oct 23, 2009 | Garmin nuvi 255W GPS Receiver
Can I programe my nuvi205w with address from my
No, but you can save addresses in your
"My favourites folder"
Then go to "my favourites" to use the address, for quick input.
You can back this data up to your Pc too, but you can't just Enter on the Pc keyboard and transfer to Nuvi.
Regards
Richard.
Jun 18, 2009 | Garmin nuvi 205W GPS Receiver
GPS Logo
21 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
