Question about Boating
Trim material, crome parts on bow of boat. - Boating
What does a trim tab do on an outboard motor
Reduces the force of the outboard motor pushing the stern down and the bow upwards which increases the available thrust to push you forwards
Feb 19, 2017 | Boating
How do I find the right way to measure the boat I got. For beam and max draught and max height for me to apply for rego.
LOA (HOA) - Measure from Tip of bow to transom
LWL - Measure from curve of bow at waterline to transom
Draught - Measure from waterline straight down to a line that interesects with lowest part of keel
Dec 06, 2014 | Boating
Evinrude power trim wiring
I think I would got back to that dealer with the boat in tow .
Jul 01, 2014 | Boating
Evinrude 1998 power trim doesn't go down when on plane?
take it back to dealer that installed .
Fuel tank capacity for 2003 18' open bow seaswirl boat
fill it to full then pump it off into 5gallon cans .some tanks were marked but many were not .if it half full top it off then guess how much the bottom had in it.
Jun 25, 2013 | Boating
I have two 36 volt 107 lb thrust Great White motors mounted on the port and starboard sides of the polling tower of my flats skiff. My fishing application has changed and I wish to mount one of the motors...
Yes it should do, this is the bracket
Motorguide MGA515A2 Great White Troll Motor Removable Mount 17031 eBay
schematic of parts
http://www.boats.net/parts/search/Merc/Motorguide/2006/950010220/Gator%20360%20Flex%20Mount%20(Black)(MST9360FW)/parts.html
this is the installation instructions for the Gator 360
http://www.motorguide.com/userfiles/file/Support/InstructionSheets/Gator-360-Flex-Mount-Instruction-Sheet.pdf
Jul 23, 2017 | MotorGuide Boating
1974 cobalt power trim selonoid replacment
What you need to do is a Web search for the brand of inboard/outboard or outboard motor you have. For instance "Mercruiser trim solenoid" and the aftermarket companies that supply those parts will appear.
Also if you have a Marine Salvage place close, you can take your solenoid and match it to a used part.
Or once you have a part number you can find parts on Ebay or Craigslist.
An outdrive from a Cobalt can be the same as any other boat, just get the correct year and Series.
Apr 13, 2010 | Boating
I have a 1200. I'm looking for the trim piece, EDGE, of the fairing, left side. Prefer twilight color, but will settle... thanks Don
auto parts store, door guard(trim or piping).comes in colors crome and rubber. it is flexable and can be shaped.
Mar 17, 2010 | 1986 Honda GL 1200 Aspencade Gold Wing
How to install trolling motor
If it is a bow mount model, then you basically need a bow mount bracket attached to the bow of your boat. If one didn't come with the outboard, you will have to buy one from the same manufacturer or an after-market one suitable for your boat. If in doubt, consult the local boating or marine store or wherever you purchased the motor or the bracket from.
Mar 15, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Boating Logo
24 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
