Question about Logitech Computers & Internet
Need info on logiteckeyboard key and go - Logitech Computers & Internet
Reset security .. engine shutdown .blinking security light
need more info yr make ,model, not knowing that here is a possible solution try lockin doors then unlock with key this can disarm system,try dr door fisrt no luck try pass door ,chip in key could have gone bad but need more info
Dec 18, 2014 | Cars & Trucks
Wrong answer not for a car for a computer keyboard need help to progarm them
Look for different coloered keys the function key is usually near the control CRTL key and works in conjunction with the function keys . eg press the funtion key and the F* key at the same time to get the requested result _ voolume up / volume down/ FF REW etc
Mar 06, 2014 | HP Computers & Internet
Need to key number twice to send a fax
Its something that can't be changed... its to prevent faxing private and protected medical info or legal info to wrong #...
Dec 30, 2013 | Canon FAXPHONE L170 Plain Paper Laser
Do I need a programed key for 2004 galant?
Program a new key?
That info would be in an owners manual
We have no source of info other than what
you have using the internet
I would call a dealer & ask--- fastest way to get an answer
Oct 10, 2012 | 2004 Mitsubishi Galant
Info key controller
donwload the instr. manual from www. retrevo.com
God bless you
Sep 29, 2012 | Televison & Video
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here: http://www.sportline.com/manuals/370.pdf
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
Jan 02, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
I need my wep key numbers
Open the device page, navigate to security settings and the WEP key info should be in there, if it is asterisked out, simply set security to no wep no wpa and save the info. then if you want generate a new wep key
Dec 29, 2010 | Computers & Internet
I need more info on the info keys, what the function of the key are.
Function Key are F1 - F12 , Fn . What info u require
Mar 25, 2010 | Computers & Internet
Key will not turn in ignition.
as a key gets older it wears down. I have had this problem before. call a locksmith shop ask them waht info on the car they need and bring the info and your key to them, they will make you a new factory key which should work unless your ignition is faulty.
Feb 03, 2010 | 2003 Dodge Caravan
I have lost my keys. what info do I need to get
Visit sentrysafe.com for instructions on replacement.
Jun 23, 2009 | Sentry Fireproof Safe
Computers & Internet Logo
22 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
