Question about The Office Equipment & Supplies
How do you open the printer access door? - The Office Equipment & Supplies
    Master:
  • The Master
  • 641 Answers
You need to be more specific . Please add the model of your machine
Posted on May 17, 2017
Error code 3806
From Kodak support:
Open the printer access door.
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer.
Turn the printer on if necessary.
After the printer has powered up, the message "Printer access door open" will appear.
Close the printer access door.
Remove and install the printhead two times.
Wait until the printer is ready to use.
Jun 07, 2012 | Kodak   ESP5250 Es Printer
Code 3514 keeps coming one
Error: "Rear access door open" (3514)
How do I resolve the error message "Rear access door open" (error code 3514)
To clear the "Rear access door open" error message:
  1. Remove the rear access door from the printer.
  2. Reinstall the rear access door on the printer and verify that both latches are securely engaged.
  3. Unplug the AC adapter from the printer.
  4. Plug the AC adapter back into the printer.
  5. Wait for the printer to initialize.
  6. Verify that the error has cleared.
Mar 18, 2011 | Kodak Office Equipment & Supplies
Error # 3802
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  5. Close the printer access door.
If the error continues:
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error continues, contact Kodak.
Nov 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error 3806
You can try the following workaround:
- After the printer has powered up, the message "Printer access door open" will appear.
To install a print head, please checkout the link below:
http://selfservice.kodak.com/service/main.jsp?t=solutionTab&ft=searchTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&solutionId=1771
If the above solutions fails. You may need to consider going to a local service center for further assistance(possible hardware failure).
Oct 28, 2010 | Kodak Office Equipment & Supplies
Printer error : 6203 comes up.
Follow these steps:
  1. Open printer access door
  2. Turn off power,wait for 30-40 seconds,then turn on power
  3. Now turn on printer and it will show 'access door open'
  4. Close printer access door.
I hope this error 6203 will not occur then!
Cheers!!!
Oct 19, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer shows error code 3802 printer will not print
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
What is error code 3802?
"Printhead failure" - #3802 Solution (from Kodak website):
Feb 16, 2010 | Kodak ESP 5 Printer
Access door open
Kindly close the access door then.If you are getting the message even after closing the access door,its time to call kodak at 1800 421 6699 and the printer will be replaced free of cost for you.Access door is the door that is opened to change the cartridges.
Sep 25, 2009 | Kodak ESP 5 Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Blinking orange light on hp 932c
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Jun 17, 2009 | HP DeskJet 932c InkJet Printer
35 people viewed this question
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
