How to install ink cartridges? - Office Equipment & Supplies
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
Whats the meaning of error in canon e5 error?
"E5: The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur."
Jul 22, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Won't print after replacing cartridges
The following text copied from HP website to tackle this problem. minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
  1. Verify that the unit is on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00718797.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Remove the new ink cartridge from its packaging.
  5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
  6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
  7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  8. Close the ink cartridge door. Figure 5: Closing the ink cartridge door c00718798.gif
s.gif s.gifHave a Good Day
Jul 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
I want to install ink cartidges and do not know where to begin. I have misplaced my instructions
To install your Brother machine#s ink cartridges, follow the steps
listed below:
1. Make sure that the Brother machine#s power is turned on.
2. Open the ink cartridge cover. This cover is located on right-hand
side of the Brother machine#s front panel.
3. Pull down the four lock release levers. There is one lock release
lever for each ink cartridge.
4. Take the ink cartridge out of its protective bag.
5. Carefully remove the yellow protective cap from the ink cartridge.
- DO NOT touch the side of the ink cartridge covered by the yellow
protective cap.
- Take care when removing this cover to prevent spilling ink and
staining your hands and clothing.
- If the cartridge cover comes off when you open the bag, the cartridge
will NOT be damaged.
6. Install each ink cartridge in the direction of the arrow on the
label.
- Please note that each color has its own specific position. These
positions are indicated by the colors of the four lock release levers.
Do not install an ink cartridge in the incorrect position, as this can
cause print quality problems.
7. Lift each lock release lever and push it until it clicks into the
closed position.
8. Close the ink cartridge cover.
- If the LCD shows #Install Black,# #Install Cyan,# #Install Magenta,#
or #Install Yellow# after you install the ink cartridges, please verify
that you have installed the cartridges correctly.
NOTE:
* DO NOT remove the ink cartridges from the Brother machine unless you intend to replace them. If you do, it may reduce the quantity of ink left in the cartridge, which may cause the Brother machine to miscalculate the amount of remaining ink.
* DO NOT shake the ink cartridges. If ink stains your skin or clothing, wash the affected area with soap or detergent immediately.
* DO NOT repeatedly insert and remove the ink cartridges. Doing so may cause ink to seep out of your cartridges.
* If you mix the colors by installing an ink cartridge in the wrong
position, clean the print head several times after correcting the
cartridge installation.
* Once you open an ink cartridge, install it in the Brother machine and use it up within six months of installation.
* Use unopened ink cartridges by the expiration date listed on the
cartridge package.
* DO NOT dismantle or tamper with the ink cartridge. Doing so can cause ink to leak out of the cartridge
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Install black cartridge, but will not print
Lets do it this way. Follow these steps again carefully and try to install the Ink.
Introduction
Follow the instructions below to replace the ink cartridges.
Replacing the ink cartridges
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging.
6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
7. Press down on the gray latch until it clicks into place.
8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
9. Close the ink cartridge door. Print a test page.
If after doing this it does'nt work, then i will ask you to unplug the printer cable from the computer and uninstall the printer driver/Software completely.
Shut down your computer and restart it.
Re-install the printer driver/software from the start as you did when you bought it.
Good luck
Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Installed new black and color cartridge.
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
Are they Canon ink cartridges?
Remove the cartridges, make sure that the tape is removed , and re-install them. Make sure they are seated correctly.
For future reference , these are the error codes for your printer.
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Loading the ink cartridge
Please remember to rate other users who assist you for free :)
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
924 says that black ink cartridge not installed
Hmmm....that sounds to be an issue with the ink cartridges...
You might be using ink cartridges purchased other than Dell or Staples...since these are the two who sell Dell Ink.
If thats not true, then take out both the cartridges in the printer.
Lets isolate the issue
1. Try only Black cartridge on Color slot(right). If you get Install both ink cartridges error, then its an issue with the Black ink cartridges and if you get message that install Black ink cartridge then its an issue with the prrinter.
2. Now install only color cartridge on Black cartridges slot(left), If you get color cartridge missing then its an issue with the Black cartridges which you are using and if you get install both ink cartridges then its an issue with the black slot on printer.
3. If issue found to be with Black ink cartridge then wipe the Nozzles(bottom) of the ink cartridge with lint free cotton cloth from back to front 5-6 times.
4. Also try replacing the ink cartridges purchased only from Dell or from Staples. Purchased from somewhere else or refilled might not work.
5. If issue found to be with printer, then i would suggest you to purchase new printer then.
Hope this fix the issue
Aug 14, 2008 | Dell 924 All-in-One InkJet Printer
Install ink
Installing / Removing Ink Cartridges To print normally, install or remove ink cartridges in an orderly procedure. Installing ink cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover).The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support <1> is fixed into position, release your hands.
    *MP470 shown
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
I hope it helps!!!
Dec 08, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Mp 460 tryin to insert ink for the 1st time
Your post is in the wrong place. I almost got you the wrong directions. LOL
Issue: How do I install the ink cartridge(s)?
Solution: Installing / removing ink cartridges MP160 / MP180 / MP460
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
Nov 12, 2007 | Brother HL-2040 Laser Printer
k24674
jasbo
jasbo
