Question about Boating
TRYING TO FIND OWNERS MANUAL ON gALAXI BOAT. This is the tri hull type, 15 1/2 ft.
pdbaker6
  • 70 Answers
SOURCE: split hull
V out the cracks with a grinder, cut fiberglass matting with an overlap of about half an inch. pre-cut 6 more pieces gradually stepping overlap to 1 1/2 inch starting with smallest piece soak in resin and place over v'd out crack, once all pieces are in place press out any air bubbles. takes a while to dry. once dry sand flat with 36 grit then 80 and 150. place a gelcoat on top
Posted on Jun 22, 2009
The Jed
  • 42 Answers
SOURCE: would like to download owners manual for 15 ft.
Although I can't find the exact model number you seek, all Kenmore manuals should be available from the following web site:
http://www.managemyhome.com/mmh/owner_manuals/search?query=Kenmore
Hope this helps.
Posted on Aug 27, 2009
Testimonial: "thanks,this will do it."
SOURCE: I am looking for a boat manual for a 1995
we contacted a boat place in port isabel
Posted on Aug 30, 2009
pctech1
  • 1940 Answers
SOURCE: I own a Clarion XMD2
Here is the Owner's Manual for the XMD2:
http://www.planetnautique.com/CorrectCraftManuals/Clarion.pdf
Posted on Feb 18, 2011
  • 41 Answers
SOURCE: Not getting correct readings from
you need to mount it or stop it lifting off the hull tthen move with it sucured
Posted on Jul 13, 2011
Looking for which boat motor modle number of block used buy the hull number will that tell me anything
The manufacturer of the boat should be capable to give you the make/type/power/serial information if you give them model and serial of the hull.
At least if it wasn't changed during the lifetime of the boat.
Aug 08, 2017 | Boating
What can i do to stop the flashing of the depth finder at times it will not show the current depth
Hey Joe,
Wow.. where to start.. there are so many things that will cause the issue you are describing.What type of electronics do you have? Does this happen at all speeds? Where is the transducer mounted? I need more info about when it stops reading.
1.Wrong setting on the unit
2 Bad transducer
3 Bad transducer mounting (either inside the hull or outside the hull.)
4. (In hull) Turbulence going under the boat (mine quits reading at about 55 mph @ half trim...the boat is lifting so much it causes air pockets so the transducer loses contact with the water)
5. (Outside hull) Turbulence around the bottom of the boat where the transducer meets the water.
Good luck,, when you get the info.. reply to me..
Jun 03, 2017 | Boating
Is there a owners manual for a EBBTIDE Boat, Serial number 41255 HULL # ETC41255M84F Thank you
When all else fails, do a search for what you need, online. I found this url for the Ebbtide boats website: http://www.ebbtideboats.com/
May 02, 2017 | Office Equipment & Supplies
Looking for an owners manual
got a picture of it
the length is not the norm
might be a one off custom build
a basic tri hull lengthened
only a few tri hull makers back in the 80s but up to 15 ft
the 302 V8 is a long running engine cant trace much from that
the engine repair manual is simple eneough
May 03, 2016 | Cars & Trucks
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
What to do to get boat to plane out
Try adding a plane to the lower unit of the outboard motor.
SE Sport 200 Hydrofoil
This will plane out the boat quite well.
Jan 05, 2015 | Boating
U have a 1971 15 ft phantom bass boat tri haul , the tag is missing , how big of motor will it handle legally ?
I had a 1976 15 ft checkmate. Low sides. It was rated at 100 hp. A 100hp in those days was pretty big. My 90 was a 6 cal merc. Todays motors are much smaller for the same ratings. A 75-90 3 cyl should work nicely and be safe.
Sep 19, 2014 | Boating
Transducer is throwing up a large Rooster tail.I installed it to instructions
Might help to tell us what kind of boat - deep V hull 22 ft.? bass boat with shallow V hull? Some need the transducer closer to the centerline of the vessel while others do better more outboard, Naturally they need to be flush with the hull no matter where they are located. Depending on the transducer, you could also try properly mounting it inside the vessel near the transom. Good new is you are getting good info from it. Cheers Pete
Nov 16, 2017 | Humminbird 586c
Holes shot in hull how do i fix
hi is the hull made of fiberglass, if so you can normally buy these type of repair kits from car spares shops, they include fibre glass resin and sealer, good look.
Oct 30, 2010 | RTO Pelican Monaco Pedal Boat
Boating Logo
24 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
