Question about Home Security
I have a Mosler 5 drawer combination safe. Serial no. 2580979. One of the drawers won't open. safe is about 30 yrs old. How can I open the drawer without tearing the drawer apart?
SOURCE: Go Video VCR/DVD Combo DVD drawer won't open
I opened the back & saw that there were no belts, etc. Put it all back together again, held the DVD door open, focused a bright flashlight into the opening, pressed eject, and saw that there was some sort of little lever(?) on the right that wasn't engaging. So I pushed it with a small sharp object while simultaneously pushing the eject button, and the tray ejected! I will take a chance and try to copy a video to the DVD again, hoping that when it is done I will be able to get the DVD to eject. I have only a few more family videos to copy (luckily I had already done most of them), so hopefully it will continue to work until I have finished the job. Thanks for everyone's ideas & help! I would buy another one of these video -to-DVD machines if it were available, but alas, the only ones I've seen are about 4 times as expensive as this one, and not worth it for the small amount of copying I have left to do.
Jazzytina
Posted on Jan 31, 2009
MNTECH
  • 1543 Answers
SOURCE: soap dispenser drawer jammed
I would not say that is normal wear and tear, but the fabric softener or bleach dispenser may not have gotten replaced correctly after they were removed. You should rarely have to clean these out (as they are flushed with water on each cycle) Make sure they are installed correctly and you should not have repeat problems. Now, Here's a possible solution to the current jammed dispenser: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
Posted on Feb 06, 2009
RescueTech
  • 145 Answers
SOURCE: f2 flashing on lower drawer
F2 means "motor not sensed to be rotating"
You said "very rarely used" also. The two go hand-in-hand in most cases. If you leave the drawer sit unused for months and months, this can ruin the motor rotor. The rotor comes out with no tools. Remove the dishrack, the wash arm (both simply lift off) and then the stainless steel filer/cover. This is removed by rotating the collar counter-clockwise and lifting it up. Now rotate the collar for the rotor counter-clockwise and lift the motor rotor out of the pump base. See if it spins freely. it;s probably frozen. You also can try swapping the rotor from the upper drawer into the bottom and see if that will work for you. if the rotor is bad, it is a part number 525884P and you can get them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
If you find this info to be accurate and correct, please rate my answer as a FIXYA.
Thanks...
Posted on Feb 08, 2009
lessmith49
  • 5 Answers
SOURCE: Lost combination Safe Guard Digital Safe
I used to work for a safe company.
The solution to your problem is not nice.
You need to find someone with a 9 inch grinder and a metal cutting blade.
Don't bother to try to cut the door off it is the strongest part.
If possible cut the back off. If not possible to get to the back start with the hinges if you know where they are, some hinges are concealed and are not where they appear to be.
This solution is messy dirty noisy and dangerous, that's what safes do to deter criminals.
If safe companies kept generic codes to open any kind of safe they wouldn't be,,,,,,,,,,,,,safe.
Posted on Feb 13, 2009
  • 80 Answers
SOURCE: lost combination to safe
http://www.sentrysafe.com
the instructions are located link above.
mj
Posted on Sep 07, 2009
Bottom oven drawer stuck partially open. Cannot close or fully open. Model #316471000
Hello Dan, thank you for your post!
I understand that the bottom drawer of your Electrolux range will not close and it partially open. It is possible that your rail or drawer may be damaged or blocked. I would recommend pulling the drawer out to inspect it. If you pull the drawer out there should be tabs on the side to unlock in order to remove the drawer fully. The model number you have provided is invalid you can locate the model number on the serial tag. The serial tag can be found on the frame of the drawer. I look forward to assisting you. -Matt
Dec 25, 2015 | Electrolux 30" Self-Cleaning Freestanding...
What does it mean if the red and green light flash together???
Do you have a key ??? try your combination and A or B
Open with key insert new batteries and reset combination.
Feb 14, 2015 | Honeywell Safes Top Opening Drawer Safe...
Can not open dvd drawer.
Sometimes drawer failure is due to dirt and debris but it also is possible that the mechanism has failed, especially if yours is an older player (5 yrs +).
May 26, 2014 | Televison & Video
Dregdrawer Full
I read somewhere that there is a counter in the machine that when a certain amount of shots are done, the counter will reach its limit and tell you to empty the drawer, even if it's not full.
When I get the message I open the door, remove the drawer and it goes away once you replace it. Don't know why the machine would stop working though?
Apr 28, 2010 | Gaggia Titanium Espresso Machine
My CD drawer will not open or close
I had a mini system with the same problem, out of guarantee so was either fix it myself or bin it.
I opened the unit and removed the whole cd drawer assembly from it's housing. I then, not really recommended, plugged it back in and by pressing the open/close a few times the drawer finally opened. Put it all back together and it now works fine. I think what had happened is that I use the cd player once every couple of months and combined with the lack of use is the fact that there are several smokers in the living room and basically it got jammed by a build up of nictotine or whatever.
Apr 01, 2009 | RCA 5-cd 300w Stereo System Shelf System
Water leaking out through powder drawer
please take your drawer out and give a good clean also look inside when drawer is out and clean there as well good luck regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
How to eject cash drawer pos
Open the Cash Drawer
Hex code
<1B><70><30><40><50>
Apr 03, 2008 | Epson TM-U220 Matrix Printer
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
