Question about Dryers
It makes a loud squeaking noise like a fan belt or something while drying?
  • 2,290 Answers
The bearings might be dry on the drum.The blower fan might be dry as well.
Posted on May 17, 2017
Check the fan belt tension. If it still makes a squeaking noise then put graphite powder on the fan belt.
Dec 03, 2012 | Cars & Trucks
My dryer makes terrible noise when tumbling. It is a loud squeaking noise. Is it a belt that needs to be replaced?
Loud squeaky noises are usually a dry bearing--in this case, probably the one(s) that hold up the front of the drum. Open the top to inspect, then remove the front panel to replace or repair. Hope this helps!
Oct 23, 2010 | Frigidaire Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
Dryer makes a high pitch squeaking noise
This could be a dry support bearing, a dried out drum seal or something stuck in the drum seal. If I could hear it I would know better where to start. Listen and try to locate the source from the above list. It could be the belt but that is not as common.
May 20, 2010 | Dryers
My crankshaft is very wobbley and make a very high pitched squeak
You need a harmonic balance. Very common problem!
May 21, 2010 | 1995 Geo Prizm
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Noise coming from fan motor
this could be a drive belt or a dry bearing what ever it is you should get it sorted out,,, pull the unit out and find out were the noise is coming from if its a belt replace it if its the motor, it may need new bearings as there sealed type you cant just swill it with oil as nothing will get to the bearings the motor will need to be striped down to fit bearings in it
Nov 06, 2009 | Samsung RS2578BB Side by Side Refrigerator
Loud squeaking noise
dont spray that on the belt lol that stuff is flamable i think lol you most likely have bad phelt glides  they are pads that sit between the drum and the drum support and when that wears out it squicks or maybe you have a bad idler pulley which is what holds the belt maybe its rusty or something but most likelt its the pads
Jun 09, 2009 | Maytag MDE6000 Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
