Question about Pool & Spa
Repair kit for utp10p1
Impellar and housings all o rings
2 Suggested Answers
  • 990 Answers
SOURCE: I have water leaking from the bottom of the ring
You should just have a "O" ring on the difuser about a 2" ring at the center opening and one about the size you describe on the seal plate or in the pump housing. Ether one at the outer edge. You probally have a bad seal. You will need to remove the impeller and replace this before you put the pump back together. Generally if you pull the wires and take the pump to the poll store they will do this for you for the price of parts and can match your "O" ring's to the pump at the same time. This is always your best bet once you open the pump to get all this done at the same time. Good luck.
Posted on Mar 11, 2010
We have a blazemaster pump put new impellar kit in it but it still wont pump any water. have replaced all o rings and new suction pipe and foot valve there are no cracks in the casing.
Need to prime the pump. In order to overcome the air in the system you need to fill the pump with water. Check your owners manual on how to prime it.
Oct 15, 2016 | Pool & Spa
Why is the motor roaring ? is it rubing on housing or a bearing ?
It may not be you motor, but the sound of some item caught in the impellar, which is the part that causes suction. It is usually located in the upper housing, and can be accessed fairly easily. Unscrew any visible screws,(usually phillips type) and carefully lift housing off. This should expose the impellar. If debris is present, remove it.
But also check for possibly broken fins on the impellar itself. Sometimes items like coins, or nails etc, will get picked up accidentally, then spin around in the impellar housing, only to break a fin or two trying to move on. If this has happened, replace the impellar.
Dec 22, 2015 | Hoover UH70105 WindTunnel TSeries Bagless...
How to wire it from 110v to 220v...
Most pumps have the eiting diagam on the outer motor housing. What brand is the pump? Some motors have a jumper that is moved over to 220v or 110v post and the red/black(220) or white/black(110) stay on the regular screw terminals. Ground stays on the same terminal usually a green screw
Jul 21, 2013 | Utilitech 1-HP Lawn Pump UTP10P1
I have a hayward pool pump that is about 12 yrs. old and I can not get it to prime this spring
If the basket in the pump and the impellar are clear I would get a "revamp" kit. O-rings for the housing, lid and diffuser. Sounds like the diffuser o-ring is bad or missing...
Jun 14, 2010 | Hayward 3/4hp Super Pump Inground Pool...
I have water leaking from the bottom of the ring lock.Took it apart don't see rubber o-ring.Is a rubber o-ring normally installed around the outside of the impellar housing?If so do you know the part...
Mar 06, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Replaceing the wet end seal on my hot tub
disconnect power take pump out remove front plate take back cover off motor use 7/16 wrench to hold shaft unless it has a place for a flat head screw driver at the back of the motor while holding shaft unscrew impellar counter clockwise take shaft seal off impellar make sure rubber gromet comes off with seal take back seal plate off motor by unscrewing bolts thru back of motor should be 4 knock out ceramic ring replace ceramic ring with rubber side toward plate reinstal back plate install seal on impeller with with flat side with rubber gromet toward back of impellar. screw impeller back on holding shaft if the shaft is rusty and pitted clean off with sand paper b4 reinstalling impellar lube up oring around front plate screw back tight and reinstal pump.
Sep 18, 2009 | Jacuzzi Impeller, L - 3/4 H.P
I have a personal watercraft jet ski kawasaki 1100zx1 and the impeller shaft is frozen. It won't turn. What might be the cause?
only 2 things could be wrong seized motor or bad impellar bearing it is located in the impellar housing you really need to pull the whole impellar housing out of the back of the ski to find out witch one it is
Apr 27, 2009 | Yamaha 12V Air Pump
Suzuki 4hp two stroke impellar
Dropp the lower unit, should be only 4 bolts holding it on. Impellar housing should be located right on top of the lower unit. four screws it the housing slides off the shaft, insall in reverse order with ne gaskets, make sure you re- align the waterhose/pipe from the lower unit back to the head
Mar 22, 2009 | Boating
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
