Question about Inverter Heating & Cooling
TRANE INVERTER UNIT DISPLAY HC WHAT 'S THAT MEAN?
3 Suggested Answers
nitrospawn
  • 290 Answers
SOURCE: my prosine inverter 1000i/24
are you sure the batteries are still in good condition or is it being over loaded
Posted on Feb 25, 2010
SOURCE: Trane XT300 thermostat reads HOLD-AC. Unit will
My TRANE XT 300C wont turn blow any hot air. If I turn on the FAN it will kick on, but when I adj the temp, it shuts off. Any ideas?
Posted on Apr 03, 2011
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
C8 mean
irst try switching off and on the printer to reset the error.
If still there the error check the following;
Check CN983, it may be disconnected on the IH inverter.
Defective IH inverter - replace IH inverter.
Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Jul 01, 2014 | Ricoh Aficio SP C820DN Laser Printer
Gree air conditioner error codes HC
I have also use GRE ac inverter but today my ac on running sundunly show (HC )Main screen
Plz information this system
HC maens what's problem
Aug 19, 2013 | Heating & Cooling
by simply turning power off to furnace or air handler may not work but there might be a reset button in the t-stat. remove the faceplate off of the t-stat it might be in their.
Aug 16, 2009 | Heating & Cooling
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
No heating, cooling or fan.
I'm confused. You have a Trane, but are asking about the Goodman warranty. I missed something there I'm sure, sorry.
"IF" Trane has a recall or warranty issue, then any qualified technician should be able to help you with that. The parts would be provided by trane in such an event, but unless the unit is less than 1 year old, chances are you will have to pay for the labor.
Being an electricain help if you want us to assist you in troubleshooting.
This link takes you to the TRANE contact page. They can answer any warranty/recall questions you have.
Jan 21, 2009 | Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Inverter Heating & Cooling Experts
MightyMikeJr
jeff5may32
Are you an Inverter Heating and Cooling Expert? Answer questions, earn points and help others
