Question about JVC Video Cameras
JVC DR-760U: When the tape is playing, it feels like there is a flat spot on the wheel. It 'clunks' as it rotates, causing a skip in the sound and video both. Same during ffwd or rewd, only faster.
  • JVC Master
  • 5,412 Answers
The pinch wheel has been left in contact with the spindle for an extended period when out of use, causing this. Get the pinch wheel replaced.
Posted on May 16, 2017
I have an O2 Dodge ram 15102 Wheel Dr., how can I tell if a bearing is going bad in one of my wheels?
You have to jack the vehicle off the ground, then grab each tire at the 12:00 and 6:00 positions. Then as hard as you can try to wiggle the tire up and down. If there is any movement then that wheel bearing needs to be replaced.
Mar 10, 2016 | Dodge Cars & Trucks
Shifting from 4 wheel dr to 2 wheel drive, i get a clunking sound and hesitation in forward travel
check the driveshaft joints , jack it up and rotate and feel them as it sounds as one of them has stated to break ! ( wobbly joint )
Oct 10, 2013 | Yamaha Motorcycles
Problem with DR-MV5S JVC Recorder
No! that should not be a factor, there are any number of reasons the VHS is not working, broken belt, idler assembly issues to name a few, I suggest a professional.
Mar 08, 2012 | JVC DR-MV5S DVD Recorder/VCR
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
While playing a vhs tape, I only get sound, no picture. No problem with a dvd.
You may have a dirty video head, try a wet or dry cleaning tape (I recommend the dry tape) the other option is to use a brand new store bought tape T120, set vcr to sp "2hrs" and let it play the full time.
Dec 29, 2010 | JVC DR-MV5S DVD Recorder/VCR
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
I have an Elna that I learned to sew on in 1958. It works, but it makes a very loud "clunking" sound that I can feel when I turn the wheel by hand.
Sounds like the friction pulley on the motor has some flat spots from sitting in one place for an extended period of time. The parts are still available from any sewing machine repair shop.
Oct 08, 2009 | Sewing Machines
JVC gr-d350u camcorder
TRi to check the take up wheel and idler gear or capstan motor is engaged with idler gear.
Jul 15, 2008 | JVC GR-D350 Mini DV Digital Camcorder
Drum makes a clunking sound when rotating, even when empty
This machine has roller wheels in the front that are not adjustable, but rather need to be replaced if they have a bad spot or something. Usually what I see with a clunking noise(clunks once or maybe two quick clunks in succession) is that the dryer has been set down hard on the ground and has put two dents in the roller surface of the drum. To check this, just unplug it, pop the top off (3 screws in the back and tilt it up) and look at the very front edge of the drum. rotate the drum by hand (carefully so you dont pop off the belt) and look for any imperfections in the suface, such as dents. If you are getting more of a vibration type of noise, I would also suggest taking off the lower front cover then taking of the blower wheel cover located to the left side and checking that there is no lint built up in the blower wheel as well. Good Luck!
Dec 11, 2006 | Asko T781 Electric Dryer
Video Cameras Logo
55 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
