Question about Black & Decker Black And Decker FS24C Firestorm 24 Volt Battery Charger
Wiring diagram for 36 volt black and decker lead acid battery
  • 313 Answers
SOURCE: WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Posted on May 31, 2008
venexcsd
  • 1185 Answers
SOURCE: Black & Decker 24 volt battery will not hold a
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
Posted on Jun 01, 2009
SOURCE: wiring diagram for a cordless Black & Decker CMM1000 Ver 2 Mower
All set, figured it out.
Posted on Jul 19, 2009
  • 4 Answers
SOURCE: Black and Decker Electric Lawn Mower MM850 wiring diagram
I have repaired mines. It was found in the trash dump, just before street curb side trash collection. It is a very sophisticated lawn mower. It taken me a month to restore it. The problem is the housing is poor design and does not hold the pin switch securely. This is not a simple on/off switch. It is switch module with two momentary switches built in to it to work simultaneously. The hot is a normally open momentary switch and the neutral is a normally closed momentary switch. Two things must occurred simultaneously for the lawn mower to work. The AC hot has to close and the neutral to open. This is a split phase AC motor. The switch has four connectors to it. The first two has black wires to it, for the hot, that is normally open. The second two has a white wire and red wire to it for the motor's start up winding. The orange connects with the plug's white, neutral. A new substitute switch will be two individual momentary switch, one for the two black wires will be normally open and the two for the red and white wires from the motor start coil will be normally close. It will take two fingers to operate the lawn mower. I recommend you to buy a new and each switch from Black and Decker.
The problem with the system is not the switch, but the poorly designed switch box housing. Often, there is nothing wrong with the switch. I tested mines and it works fine. The problem is the switch box housing does not keep the switch in the correct position for the higher tension spring lever to press against it to operate. I use small washers to stack between the rear of the switch inside and reassembled the switch box upside down by turning the handle upside down, so the washers and switch do not fall out. Once I am finished assembling the switch box and position it on the handle, then I position the handle back to the normal top side and attach the handle back to the lawn mower. I am finished.
http://en.wikipedia.org/wiki/AC_motor#Split-phase_induction_motor
"Split Phase Motors
Split phase ac motors are widely used for low power applications as for example in oil burners, furnace blowers, garage door openers and major appliances. Such motors employ separate run and start windings connected in parallel across the acpower source. When the motor is initially energized both windings are energized, and when the rotor speed reaches about eighty-five percent of the normal running speed the start winding is disconnected from the circuit. Various devices are utilized forthis latter purpose and include centrifugal switches and current and voltage relays.
A problem which is characteristic of these motors is that they have a relatively short operating life. The principal reason for this is the failure of the switching devices used to cut out the start windings when the rotors approach the normalrunning speeds.Failure of these switching devices in turn cause the start windings to burn out.
One of the reasons for the failure of these switching devices is the high currents which they are carrying at the time the contacts open. Attempts to increase contact life by use of improved designs and materials have not been altogethersuccessful. Another disadvantage associated with these switching devices is that they are necessarily quite large and occupy a substantial space in the motor housing." -from another web site.
Posted on Sep 08, 2009
  • 23 Answers
SOURCE: WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER MM 850
looking down at the terminals, rotate push-button to the right. the wiring sequence is R, W at the top, then Black (in, from power source) , Black (out, to motor).
Posted on Sep 27, 2009
Alternator wiring
Hi Skeet, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in aprerage then get out your test light and track down the short in that circuit.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v while cranking replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor.
17. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Aug 18, 2013 | Harley Davidson FLHTC Electra Glide...
1995 FLHTCU WIRING DIAGRAM MANUEL
Hi Anonymous, perform the following tests:
3. Make sure all connections are clean and tight especially the negative cable at "BOTH" ends.
17. For a free wiring diagram please visit the website below. Good luck and have nice day.
Aug 23, 2012 | Harley Davidson Motorcycles
Looking for a wiring diagram for 2003 Heritage.
Hi Ernie, perform the following tests:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
May 31, 2012 | 2003 Harley Davidson FLSTC Heritage...
Powerpack 400 plus When 115v switch is turned on AC light is on but alarm sounds and has no output
Hi, I bought a new Black & Decker one of these and when I got it home and charged it, it acted the same way. I assume it has an internal battery. These gel-cell spill-proof lead acid batteries will dry out and one cell will loose power for a load, but will indicate "full". 99% of these batteries have replacements available on line under S L A (spill-proof lead acid) batteries, or if you have a friend with a WW GRAINGER account, they stock them.
Mar 02, 2012 | Xantrex Technology Xpower Powerpack 400...
How do I know if my battery is bad or if my charger is bad? The red light on my charger no longer lights up when I plug it in. This is for my Black & Decker Firestorm 12volt drill. Thanks
With a multimeter set it to 12 volt dc and place the leads on the two parts that would be touching the battery. If you see voltage then it is a bad battery.
-David
Nov 08, 2010 | Black & Decker Black And Decker 12 Volt...
I need a replacement for the 3 sealed lead acid batteries in the Black & Decker "Simple Start". It sat too long & sulphated. The batteries are "SEL C83-6"
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from: www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Jul 31, 2010 | Vector 2M Pwr Rch Spotlight
Can i run my minn kota 30 trolling off my power box
Are you referring to an inverter by a "power box"? That term doesn't really describe the device. I'm going to assume it's an inverter you're talking about, a device that takes DC and turns it into AC. I'm not sure about that, but you should be able to plug a converter (turns AC into DC) of the right voltage, 12 to 14 volts DC into a generator on the boat and run it. I'm assuming the trolling motor runs off 12 volts DC and NOT gasoline. Be sure to check that before doing anything. Most do run off a large car or RV battery. Lead Acid Batteries for boats and cars produce 12.7 volts DC if they are in good shape and should have six cells (about 2volts per cell). 6 volt batteries are somewhat rare these days and have 3 two volt cells. Two of them in series will also power it.
Thanks for asking that question ... I like to fish also.
Lynn
Mar 20, 2010 | Black & Decker PI400AB Power Inverter
Sep 27, 2009 | Black & Decker 19" Electric Lawnhog...
I had the same problem, the batteries are burned out, I know you can replacements at Home Depot but if you can wait try the interenet.
"Google" what you want.
Mar 01, 2009 | Black & Decker Black And Decker FS24C...
Replacement batterys for cmm1200 black&decker electric mower I have a Stealth Black & Decker rechargable mower and would like to know what battery I need and can I replace it myself Thanks Cherie
I discuss the solution to your problem in my review. I am using a replacement AGM Lead Acid battery that increased my mowing distance and does not take more power to charge because the battery has an lower internal resistance. The battery is a Power Sonic, PSH-12180FR, 21Amp Hour unit. You will need to order two of them.
We should all do our part to save the enviroment and encourage the growth of the solar and wind power industries.
Cordless electric lawn mowers go a long ways towards these goals. I recently purchased the Black & Decker Cordless Electric Lawnmower the CMM1200.
In the review I describe how to upgrade the mower to mow over 9,000 SQFT!
I hope my review will help you make a decision about our future.
http://www.epinions.com/review/Black_Decker_19_In_24_Volt_Cordless_Mulching_Mower/content_445899312772
Sep 30, 2008 | Garden
Black & Decker Black And Decker FS24C Firestorm 24 Volt Battery Charger Logo
60 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Rabbit Brains
Rabbit Brains
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
