Question about Garden
PTO switch does not make blades work bought a new switch but still won' engage the blades any suggestions
  • 246 Answers
SOURCE: Husquavarna GT2254 runs fine till I try to engage the blades,
Hello janec37415:
>>From your Description it Sounds like the Seat Safety Switch is Bad, has a Bad Connection or the Stator/Charging Coils are Not Charging Enough for the PTO to be Engaged.
>>When the Blade is Engaged, the Seat Switch is Showing No One is on the Seat so the Engine is Shut Off by the Safety System or
>>When the PTO is Engaged and the Stator/Charging Coils are Not Charging Correctly, the Carburetor Solenoid Does Not get enough Voltage to Stay Open and the Engine Quits.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
  • 138 Answers
SOURCE: pto not engaging blades
Lets start from the beginning:
Do you have power going to the switch you need to check this with a volt meter it should read between 12 and 13 volts with thew engine off
if you have power to the switch next we need to check to see if there is power coming out of the switch again check with a volt meter.
if you have power coming out of the switch then we need to see f power is getting to the relay on the battery terminal and the switch terminal and if there is power to both terminals then we need to see if the relay is functioning correctly ( check output terminal with voltmeter)
If we have power to and through the relay we need to see if we are getting power to the clutch ( check this at the clutch) if there is no power to the clutch trace your wires back until you find power and make the repair. If ther is power to the clutch but the clutch does not engage you may have an open ground meaning the circuit is not complete again check your wiring. If everything checks out but the clutch does not engage then you have a bad / open in your clutch hope this helps
Posted on Aug 21, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
I have a ariens zoom 1540 mower it runs fine but the blades wont engage to mow. It worked when i put away after last mowing and 2 days later it doesnt. Ive checked the wires off pto switch and they seem...
You've checked the wiring to the PTO and it looks OK. Does the PTO engage when the switch is thrown? Do you have a multi meter , so you can trace the voltage to the switch, from the switch to the PTO. You also should check the safety switch (s) which will prevent the PTO from engaging if there is a faulty switch. And it could simply be a fuse that has blown.
Jun 20, 2014 | Garden
Scotts L2048 lawn tractor deck wont engage
You need to check the wires from the clutch, with the ignition on pull the pto switch out there should be a 12 volt supply at the wires if not replace the pto switch, if you have 12 volts then it is the clutch itself, they are not realy repairable, so may need a replacment.
Jul 16, 2013 | Garden
Lawn tractor, blades won't engage
the circuit also goes to the trans so you can't mow in rev also on the brake/clutch pedal switch assuming you check the fuse already
May 10, 2012 | Husqvarna Garden
John Deere SST16 PTO won't engage mower blades
check for power at the clutch if no power check the safety switches and the switch itself
Apr 23, 2012 | Garden
DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Apr 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
