Question about Whirlpool Washing Machines
Whirlpool WTW4900BW1 Washing Machine Loud Banging on spin cycle.
I have a Whirlpool WTW4900BW1 Washing machine. Recently purchased from an older couple who said it worked well with no problems. When I picked it up from them, I had to lay it down on its side in my SUV because it was too tall. Once we hooked it up, it works well. Fills properly, spins and drains properly. However, when the spin cycle starts there is a loud banging noise (sounds like tub is hitting outside washer case) It happens a few times, then stops and may do it again a few minutes later. It is very loud. There is also a slight grinding? sound when the washer is agitating but my wife thinks that part sounds normal. Just wanted to mention it in case it is related. I looked a little bit online and saw the suspension may be worn out. I checked to make sure they are all in place in the frame and on the outer tub, and they are. Not sure if the issue is from laying it down (which I probably shouldn't have done) or something else. Please help!
  • Whirlpool Master
  • 2,355 Answers
Are springs and shock absorbers in place?
Posted on May 17, 2017
    Top Expert:
  • Whirlpool Master
  • 43,901 Answers
Transporting a washing machine in any position except upright can be fatal. The reason? The original packing material is no longer in place.
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
My whirlpool top loader extra large washing macine
Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
Aug 07, 2008 | Washing Machines
Loud banging noise during spin cycle
If you balanced the machine, the only other problem could be the load itself. Either the load is too great or if washing a single item its falling to one side, tilting the drum and when spinning it will thump. Try even lodes.
Jan 31, 2018 | Washing Machines
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
My washing machine makes a very loud banging noise at the start and end of the spin cycle and there is a scraping sound throughout the cycle as though there is metal in the drum. What could be causing...
If you have an older machine it is the un-even load distribution in the wash tub. The wash is not evenly distributed in the wash tub. The wash tub don't spin evenly and wobble instead.
Mar 30, 2012 | Washing Machines
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal De
