Question about Poulan Garden
NEED A REPAIR MANUAL OR A POULAN 2055 CHAIN SAW PLEASE
    Master:
  • Poulan Master
  • 645 Answers
There are no repair manuals offered by Poulan. There may be an aftermarket company that could supply, but I did not find one.
Posted on Dec 04, 2017
Idaho_Biker
  • 32 Answers
SOURCE: 38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Posted on Jan 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: locate exploded drawing of poulan chain saw
I tried a couple locations and found a site that might help go to psep.biz and it will direct you to the blowup. It also indicated that it needed a type number so have that handy. If this doesn't help let me know and I will research further.
  • 398 Answers
SOURCE: I NEEN A OWER MANUAL for a poulan chain saw 2150
its pretty easy to do with a file. first make sure you buy the right size file to fit right in the tooth. look closley at the chain and figure how to place the file on it. the point is to sharpen the side and top of the cutting part of the tooth .always file one way away from yourself. hold the file at an 45 DEGREE angle, and push forward. the trick is to push forward and up at the same time, and always go one direction. start on one side and mark your starting point with tape, go down one side then flip the saw and down the other. you dont have to push hard just enough to were you can see tiny metal fall off. lemme know if you have a problem
Posted on Mar 21, 2009
odiebugs
  • 949 Answers
SOURCE: Need User Manual Poulan 285-Pro18'' Chainsaw
Here is the manual, you need adobe reader to see a pdf file, also below is the page for the reader it is a free download.
chainsaw
http://72.3.225.179/manuals/67181.pdf
abobe--
http://get.adobe.com/reader/
Hope this helps,any other questions please post back,everyone is more then happy to help you.
Posted on Mar 24, 2009
slohry
  • 87 Answers
SOURCE: Owners manual for Craftsman 20 in chain saw, needed
Parts manual, have model # available
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 09, 2009
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
How do i change the fuel filter on my poulan 2055 chain saw?
Take a lenght of welding wire or other stiff wire, bend the end around to create a u then enter into the fuel tank throught the filler hole, hook the fuel hose and carfully pull out through the filler with the filter on the end, the hose will be long enough to do this, just pull the filter off the enf of the hose and re fit the new filter.
Sep 01, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
How do ireplace gas filter in poulan 2055 chain saw?
the fuel line rots apart you need to replace the line pull the old hose out take a new hose cut down about a half inch cutting the line to about 1/3 slide a stiff wire down the hole and out the gas cap slide the hose over the wire and slide it back til the cut back end pops out put the filter on the end and pull it into place cut to size and install on the carb
My 14-inch Poulan chain saw (2055) was working great, then it began to loose power and stumble, then stop. It restarted a couple of times, but had no power. I've checked the gas, oil, and free movement...
Two items you can check:
1. There is most likely a spark arrestor screen on the muffler. These can become clogged with carbon and choke out your saw. If it is removeable, usually by taking out a single screw on the screen, you can clean it with a wire brush.
2. Check the compression of your cylinder. It should have a minimum of 100#.
Oct 12, 2010 | Poulan 14" Chainsaw
Where can i find a service center to purhase a chain adjusting assembly for a poulan 2055 chain saw in the tampa area
Poulan Service Locater
http://www.poulan.com/node6604.aspx
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
See the "Handle, Bar and Chassis Assembly" print, item 29, $2.53
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Feb 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel line routing
A typical fuel system and a couple of suggestions follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Poulan.com
I am reasonably sure the upper most carburetor connection (it bleeds any air in the carburetor, air rises) goes to the primer. Leave the hoses long enough to swap them and try it. They can be shortened once you verify the correct routing. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
