Question about Sewing Machines
Need the GEAR HOOK for a WHITE model 746.
Your WEB displays similar Gear Hooks but for other machines. How can I compare actual dimensions of the broken part I have to the dimensions of the units you display, They are PN's 56365, 403703, 735450003, V11483000. My cell # is 915-861-6306. Please call and lets discuss how I can fix Gran'Mas Machine. THANKS!
  • 1073 Answers
SOURCE: washing machine broken, kenmore model 110.92274100
REPLACE THE DIRECT DRIVE COUPLING IT IS BETWEEN THE TRANSMISSION AND THE MOTOR PART NUMBER IS 285753A THE TRANSMISSION IS NOT BAD
Posted on Apr 22, 2008
  • 8 Answers
SOURCE: LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
Posted on May 20, 2008
SOURCE: Need missing gear that drives strirring rod for popcorn machine
Dear mpolly: I too am looking for the same gear I believe, if its the one that at the top of the long rod. Ours fell off as well and probably found by someone in there bag of pop corn. I will let you know if I find it.
Posted on Jul 18, 2008
I have the same problem as posted on mar 30, 08. seems like the clutch will not engage, the motor turns but the drum won't spin (wash. move). would you give us follow -up instructions for clutch & gear case on how to replace it.
Posted on Jul 27, 2008
SOURCE: 1972 Elna model 62C
i guess i thought i could get some help with starting the dismantling. but of course, except for chit chat, if i don't pay, my affiliation with this site is useless. my machine is 36 years old. i found sewusa that had drawings, but only limited number. yes, when i go at it cold, i will post how i removed the old gear, so someone else can get this help. cheers
Posted on Nov 04, 2008
Singer model 478 does not pick up bobbin thread,lower belt around 3 gears does not turn under power. What do I need to Know?
There is a shaft that runs from the top of the machine to the bottom, in turn driving the bottom gear and belt. Though it is hard to see, you will probably find that the gear at the top of that shaft has the teeth broken. It is not impossible to change but definitely difficult.
Apr 09, 2017 | Singer Sewing Machines
2016 Janome 4900 stopped pulling up bobbin thread. SMW/Calgary said: hook drive gear disintegrated/melted. Part $17;service to replace part $335,like rebuilding the machine. Similar issues?
The following is from their web site. If this is a 2016 I would expect that it is covered under warranty.
"During the first year of ownership, warranty service will be provided by the authorized Janome dealer from whom you purchased your machine.
If you did not purchase your machine from an authorized Janome dealer, please contact Janome America through the Machine Support section of our website for further information regarding warranty service.
After the first year of ownership, please contact any authorized Janome dealer for service"
Hope this helps?
http://janome.com/en/support
Nov 09, 2016 | Janome Sewing Machines
My riccar - model #808 - needs gears. is it possible to have these sent to me?
Yes. However, you wrote "gears" as plural. There is only one gear in that machine; the hook gear. The hook gear is inexpensive and easy to replace and retiming the hook is easy as well. There is another potential problem; the timing belt cogs. They are plastic and, over time, they split, causing the timing belt to jump off time constantly. The replacement kit (2 cogs, belt and idler pulley) is available but is extremely labor intensive and requires a high level of aptitude for mechanical repair.
If you need a hook gear, they are under $10 and can be shipped right to your door. 805-540-9294
Nov 01, 2010 | Riccar Sewing Machines
My hook gear has gone bad, I have singer sewing machine model # 834, I need help with how to take the parts off and replace them
http://www.sewingpartsonline.com/singer-834-sewing-machine-parts.aspx
Follow this link, click on the hook gear parts, and you will see a link to a video showing how to install these gears. I was able to follow this video and replace the gears on my old machine. For me it was do-able, but moderately difficult. If you think you're up to it, go for it. Replacing all for gears a t once will cost $50. (Singer 834).
Sep 16, 2010 | Sewing Machines
My Elna automatic TYPE 41C plastic drive gear has shattered. I ned a new gear
You can obtain one of these from www.sewingpartsonline.com, not sure if you mean the cam stack gear or the hook pinon gear down under the rotary hook but both are available, liks are http://www.sewingpartsonline.com/cam-drive-gear-elna-416340.aspx
or http://www.sewingpartsonline.com/hook-drive-gear-elna-star-11-sewing-machine.aspx
If you want to install yourself you may want to join the Yahoo group Elna Heirlooms, they share lots of information there on these Swiss made Elnas.
Jun 11, 2010 | Elna 2005 Mechanical Sewing Machine
Rotating Hook won't fully turn-Singer 2210
The nylon gear driving the hook has probably broken a tooth. Replacements are available if you search the web.
Make sure you get the matched set of driving gear and driven gear.
Apr 24, 2009 | Singer Sewing Machines
Bobbin drive gear
You need to get the gear from your elna dealer. To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher
Mar 18, 2009 | Elna 2007 Mechanical Sewing Machine
Needle hits?
OK, this is a general timing procedure. Loosen the screws on the main shaft gear that goes to the hook drive gear and separate the gears. Next put the needle in the left position and bring the needle all the way down by turning the handwheel. As the needle comes up make the point of the hook enter the scarf of the needle (just above the needle eye)and hold it there while you put the gears back togeather and tighten the screws. This should put it close to being in time. To fine tune it you can loosen the needle bar screw (half way up the bar that holds the needle) and adjust theneedle so the hooks point is just above the needle eye. You may have to do this a few times in order to stop it from skipping stitches. Good luck. Rick
Aug 26, 2007 | Singer 20U73
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
