Question about Vizio Televison & Video
Vizio TV remote and Xfinity remote work on all but on/off and volume. Is this a IR sensor problem ?
jan mczeal
  • 632 Answers
SOURCE: DirecTV remote won't work unless we are within 6
Replace remote battery with a new one. It may not be transmitting enough power to work more than 6 feet from the TV.
Posted on Oct 30, 2009
  • 11800 Answers
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Posted on Jun 04, 2011
  • 1702 Answers
SOURCE: volume goes up on own with no remote function
Hi, Check that buttons on TV or remote are not stuck. Good luck.
Posted on Nov 13, 2011
spr1949
  • 1182 Answers
SOURCE: We replaced the IR sensor on our Vizio but still cannot control the volume via the remote (which has tested good). Any further suggestions?
Since sensor is receiving the signal of other inputs, there is nothing wrong with it. This looks like an incompatibility issue. You may have to retry using the original remote control.
Posted on Jul 31, 2012
gopakumarg43
  • 74251 Answers
SOURCE: vizio sound bar code
034,028,075,018,072. Check these codes. If you wish to get more codes to different other brand remote controls, check this link. Code list and setup proceedings to some popular model remote controls are given in detail.
Posted on Feb 26, 2013
Ir sensor may be defective
It may be a defective remore control,They are infrared light to test one get a digital camera aim the remote directly at the cameras lens push remotes buttons you should see the pulses on the cameras lcd screen,the human eye can't see IR light but the cameras sensor can,quick test ,
Mar 06, 2014 | Vizio M550SL - 55" Class 54.64" viewable...
Ir sensor is not working
check to see if your remote is actually working, If you have a digital camera with an lcd display point the remote at the camera and push a button on the remote, if the remote IR light is working you should see it light up thru the camera when you press the buttons.
Dec 20, 2013 | Vizio M420SL 42 in. HDTV
The ir sensor is not working
The failure to IR sensor inside the TV is a very rare case. Check the infrared emission to the remote control first. Check it with fresh batteries. Make sure that it works well, before trying to replace the infrared sensor inside the TV. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
M420mv vizio led television ir infrared doesnt work
that can be caused by either the IR sensor board or the main board. The IR sensor board would be suspected first. You can get the IR board or the main board from www.tvrepairworld.com
Feb 09, 2013 | Vizio Televison & Video
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
Vizio m470sv remote stopped working, bought a vizio replacement remote...still no good????
What you are dealing with is not a bad remote controller, the problem is from your IR Sensor. You will need to replace this IR Sensor. You Vizio TV has a common defect with the IR Sensor. Make sure you order the revised version so you don't encounter this problem again. You can find the IR Sensor here: 3637 0022 0189 0171 1671 0892 Vizio IR Sensor
Oct 28, 2012 | Vizio VO Televison & Video
Jul 30, 2012 | Vizio SV470XVT 47 in. LCD TV
Volume goes up on own with no remote function
Nov 13, 2011 | Vizio L37 Television
Just bought a vizio tv Model #E470VLE, my dish remote will not control the mute or volume buttons now, how do I get it to do that?
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to readdress your DISH remote to your new Vizio TV. We have a few different codes for each of our different models of remotes. You will be able to locate the model number of your remote on the back of the remote at the top usually a two to three digit number with a decimal point. I will list here for you the best codes for Vizio TVs as well as the instructions for addressing the remote to your TV. I hope you find this information useful and if you have any further questions or concerns feel free to email directly at Cheri.Torres@Dishnetwork.com.
Codes for Vizio TVs
3.0, 3.1, 3.2, 3.4 IR remotes - 505, 671, 627 and 766.
5.0, 5.2, 5.3, 5.4 IR remotes - 627, 505, 506, 457, 111 and 520
4.0 and 4.4 IR/UHF remotes - 505, 627, 555 and 766
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - 627, 505, 678, 825, 520 and 766
20.0 IR and 21.0 IR/UHF remotes - 505, 598, 627 and 773
Instructions for addressing your remote to your TV.
  1. Turn the Television On.
  2. Press and hold the TV mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
May 22, 2011 | DISH Network IR Remote Control
Vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
18 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
