Question about Dryers
One of coil element does not work anymore. need repair or replacement it. JXGR63B
How come the burners on my general electric stove
Whenever I replace a block, it doesn't hurt to file or sand the male contacts on the surface burner. Be safe.
Sep 30, 2014 | Kitchen Ranges
I have a Jenn-Air JES9900 range and the right front burner is not working but the hot indicator light remains on. Is this just a switch that needs to be replaced?
make this test and fix it. God bless you
Surface Element Switch
If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Surface Element Board
If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element
If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element
The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element
If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Element Receptacle and Wire Kit
If a surface element won't work, there may be a problem in the element receptacle. The surface element plugs onto a terminal block type receptacle. Over time the terminals in the receptacle can have a bad connection and overheat. Look at the receptacle contacts with a flashlight. If the terminals look burnt you will need to replace the element receptacle. also make sure the element prongs are clean and not burnt. If the prongs are burnt bad the element will need to be replaced also.
Loose or Burnt Wire Connection
If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem
Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Nov 04, 2013 | Kitchen Ranges
Dryer part of the washer/dryer is not getting hot anymore
hay Darren , If you have an electric dryer it may be a element or fuse , if its gas it may be bad coil or fuse . The washing machine does not heat the water rather bring it in from the boiler therefor its unrelated to the dryer .good luck APPLIANCES R EN
Mar 01, 2013 | Washing Machines
Heat does not come on anymore
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Feb 04, 2011 | Amana NED7200TW Electric Dryer
Kenmore 80 series dryer approx 7 years old not heating anymore. Cleaned the vent pipe using semi-rigid vent tube only three feet to outdoors. Vent on exterior blowing cool air forcefully. It is an...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Here is a link to a video that will help you.
Nov 26, 2010 | Dryers
I THINK MY HEATING ELEMENT WENT OUT ON MY DRYER. HOW CAN I TELL FOR SURE AND HOW DO I REPAIR IT. IT WILL NOT DRY ANYMORE AND SEEMS TO OVERHEAT. I HAVE CHECKED THE LINT TRAP AND HAVE FOUND NO MAJOR...
first, make sure dryer is unplugged before removing cover. locate you heating element and with a multi meter or volt meter put dial on ohms setting or the setting that beeps when leads are touching together. your heating element looks like a coil of wire. remove the wires connected to each end of heating element. take the leads from volt meter and place the lead on one end of the coil and the other end on the opposite. if you do not hear a continuous beeping sound or no reading on your meter it is bad. if you do it's not. check internal clogg or the thermal fuse located near exhaust duct. the heating element has to be replaced. rwpfn@aol.com
Sep 02, 2010 | Dryers
Dryer model 110.C62212101 isn't drying clothes anymore despite the drum working perfectly. (it takes two 60 minute cycles) I presume I need to replace a heating coil? Is it simple to do myself or should I...
Check the element for continuity in back with voltmeter
Check thermal fuse at top of the element case in back
Checkfuse lower left in back
Jul 30, 2010 | Dryers
My frigidaire side by side is not cooling well anymore...10 years
, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Frigidaire FRS26ZSG
Dryers Logo
22 people viewed this question
Top Dryers Experts
