Question about Garden
21' sun deck how many people will it carry? - Garden
2 Suggested Answers
  • 10865 Answers
SOURCE: I need the part number
Hello.
You may be able to get the part number and the part you need by going to searsdirect.com and entering the model number.
If not, rather than going to a home depot go to a lawn mower repair garage where they have books available to look up exactly what size belt your machine needs. J
Posted on Aug 16, 2010
Is there a coating that I can get to protect my decks finish from the sun?
There are all sorts of stains and polishes that claim to protect your wooden deck from the harmful rays of the sun, but I haven't found any to work as yet. eventually they all fade away and have to be reapplied.
Nov 10, 2013 | Adhesives, Coatings & Sealants
Gas fills up engine block when stored
Turn your gas off when mower is not in use. Sounds like a stuck/dirty needle or seat in carburetor. If needle isn't seating properly gas can slowly trickle down and seep into crankcase on most engines. Try turning gas valve off when not in use, if you don't have an on/off valve you can add one very easily. Any local auto parts store or hardware store should carry this. You will have to cut the fuel line and insert valve inline. Eventually you will want to clean the carburetor. I hope this helps.
Aug 12, 2013 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Need diagram for mower belt deck for Craftsman ZTS 7500 42'
need a mowing deck diagram for 2008 42 inch 21 horsepower zero turn
Aug 08, 2012 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Have craftsman 21 hp 42"cut
You can take the model number listed under the seat and go to search craftsman parts, go to the sears website and use that 917.# and you will be able to see an exploded view of the deck among other sections of the mower, all other sections except the engine.
I hope this helps.
Aug 17, 2011 | Garden
Looking for v belt # 1197253 for lawn tractor not listed, do you still carry one, please list cost? thanks,ronald fortner
ronald this is not a parts store. get your phone book out and look under lawn mowers and small engine repair in the yellow pages. that will put you on to some local shops who sell that stuff and they may not have web pages. if you have no one local, then google "small engine parts" and that will find you some online vendors.
Mar 05, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Poulan pro, right out ofr the box model pr625n21rh3 serial 012010m 004039. the problem is it won't cut the full width of the deck , have to overlap 3" to get full width cut????
This is a 21" mower, meaning the blade is 21" long (maybe only 20.5") and it will cut a 21" wide path of grass. Measure the width of the path that it cuts in the grass. If it is less than 21", then the mower has the wrong (too short) blade on it. It may just have a configuration of deck and wheels that make it look like it's not cutting as wide as it should.
Jul 28, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Left side blade cuts about an inch lower than right side , the left 21" when cutting is about an inch lower than the right 21", looks terrible, checked tire pressure and that was not the problem
measure the height of cut from the ground to the bottom of the deck all the way around, if it is the same the blade or bearing housing is at fault, if it is lower on the left look for a bent or broken mount from the deck to the tractor on that side.
Jun 14, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How do i reattatch the sun canopy on the maxi cosi carbrio fix? mine didnt come with one so ive brought one just need to attatch it now x
hi maria10102..hope this helps..good luck!!!
The sun canopy is located in the rim of the shell.
• Place the carrying handle in the carrying position.
• Open the rim by pushing the button at the back under the rim and releasing it.
• The sun canopy is now visible in the opening
• Pull it out and place the ends of the sun canopy with the buttonholes over the hooks on the carrying
handle
• When storing the sun canopy, make sure you place it in the rim carefully and close the rim properly
http://www.instructions.maxi-cosi.com/download/cabriofix.pdf
Mar 11, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
