Question about The Office Equipment & Supplies
My laser jet pro map m177fw is stuck initializing, and i have tried everything. i have read several other's issues, but mine persists. can you help?
My laser jet pro map m177fw is stuck initializing. the printer has been unplugged, downloaded the most recent firmware, plugged into a different outlet, hooked-up the usb cable although, hardest, etc.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 18 Answers
I am not sure about M117fw. But my M1211nf had the same problem. Here is the fix.
Turn off the power and unplug the power case - always!!!
If you open the flatbed cover, you will see that the LIGHT bar is all the way at the end and it won't move back. Use STAR-shade screwdriver to remove screws around the rim. There are 2 screws under the plastic rim (different size). Lift the glass cover slightly and move the Light Bar to the middle. Close the glass cover and turn on the power.
If it works, turn the power off and put back all screws.
Posted on Oct 05, 2017
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 112 Answers
Please review the HP troubleshooting for your printer:
HP Color LaserJet Pro MFP M177fw
If this printer is new, you may need to make sure the toner cartridges are seated and installed correctly.
It appears others have had similar issues and solutions are provided here:
Laserjet Pro MFP M177FW stuck in Initializing
Posted on May 19, 2017
Cm1312 keeps on initializing
If under warranty call HP. The formattor board has failed, this can be a jet direct connection issue, but the jet direct board is internal.If there is a slot in back to add an external jet direct board, try that first.
Nov 15, 2014 | HEWLETT PACKARD - LASER JETS hp color...
HP Laserjet Pro M1536 will not initialize
Hi
As far as i know if the printer does not initialize it is due to bad formatter board assy. Hence you just need to disconnect the formatter assy cable and try to turn on the printer if the engine initilize then you need to replace it with a new one.
Jan 05, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
Initializing
NVRAM Initialization:
1. Turn the printer off.
2. Press and hold down CANCEL (X) and Start Copy (button just below the X button) buttons at the same time while powering on printer. *Keep these buttons press while you power on the printer*
3. Continue to hold down buttons until the printer display reads PERMANENT STORAGE INIT.
4. Release the buttons when "PERMANENT STORAGE INIT" is displayed. Printer will return to Ready automatically.
Dec 12, 2012 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Scaner error 52 in my laser jet printer printer model :-hp laser jet 3052 all in one printer
52 Scanner Error
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the FFC connection between the formatter and the scanner.
NOTE Do not bend or fold the FFCs during the removal or reinstallation process.
4. Try connecting the product to a different power source or surge protector.
5. Turn on the power and wait for the all-in one to initialize.
6. If the error persists, replace the laser scanner assembly.
Jul 12, 2011 | HP LaserJet 3052 All-In-One Printer
Heloo can you help me my hp laser jet cant print its reads 82.0180 EIO 2 error
The error message "83.0180" shows that an EIO error has occurred.
Perform the following workaround and see whether the issue still persist.
1. Ensure that the printer is connected directly to the wall outlet.
2. Turn off the printer and then power on and see whether the issue persist.
3. Reseat the Jetdirect card and see whether the issue still persist.
4. Reseat the jetdirect card on a different slot and see whether the issue still persist.
5. Remove all the accessories from the printer and then power on the printer. See whether the issue still persist. If the issue does not persist, add on the accessories onee by one.
6. Power on the printer and check whether the issue persist, each time an accessories are added.
7. Swap the Jet direct card with a known good jet direct card and see whether the issue still persist.
8. Perform a cold reset and see whether the issue still persist.
Mar 02, 2011 | Office Equipment & Supplies
My sony cybershot dsc-w350 keeps turning itself on and off and reads system error
The system error is displayed in the Camera when there is some internal malfunction or when the Lens in the Camera get stuck.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
If the issue persists, service may be required.
Thanks for using FixYa
KenSolutions
Dec 05, 2010 | Sony Cybershot DSCW350 Digital Camera
HP 4200 Laser Jet Printer Error Code 82.0180 EIO 2 Error
The error message "83.0180" shows that an EIO error has occured.
To do a Cold Reset:
1. Remove all cables.
2. Press & hold the Test button while applying power & continue to hold it for 10 seconds, then release it for 10 seconds, then unplug it again.
3. Connect all cables & power it back up.
4. Wait 2 minutes for discovery & DHCP. If desired, change the DHCP & address settings.
May 07, 2010 | HP LaserJet 4200 Printer
Ho laser jet colour 4700
Have you recently adjusted or replaced the transfer belt? This error is sometimes caused by the transfer belt being installed incorrectly, so the first thing to try is to take the transfer belt out and reinstall it, then turn the printer off and back on.
If the error persists, you may have a problem with one of your motors.
Mar 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My lens is stuck in everything eles is fine
Please try initializing the Camera to resolve the issue.
First, please press the HOME button on the Camera to display the home screen on the LCD screen of the Camera.
Then, select the "Settings" option and then select the "Main Settings" option on the Camera.
Now, select the "Main Settings 1" and select the "Initialize" option and press the middle of the control button to initialize the Camera.
Then, select "OK" and press the middle of the control button to initialize the Camera. If the issue still persists, it is required to service the Camera.
Nov 24, 2009 | Sony Cameras
Help me pleaseI have a 1720 printer from a
Goto support.dell.com and follow the troubleshooter for "Service error 1720dn" that should narrow it WAY down for you. It's probably just the hsync is off on the laser. The troubleshooting trees that they have at dell will tell you exactly why it is not working correctly.
Aug 18, 2009 | Dell 1700 Laser Printer
432 people viewed this question
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
