Question about Sharp Tools & Hardware - Others
TR-200 sharp shooter - Why won't it staple?
When I try to staple, it seems like something lets go and it doesn't fire a staple. Maybe like a spring has come unhooked and lets the mechanism slide by not pushing the staple.
    Visited the website for 30 consecutive days.
  • 664 Answers
There are no repair parts or instructions other than what came qith gun. It is a disposable unit.
Posted on May 18, 2017
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
Need instructions for a stanley sharp shooter tr45 on how to load
at bottom back of stapler find the metal clip, about 1/2 x 3/4 inch piece. push in and down at the same time. after it releases pull straight out. insert staples, assemble in opposite order
Mar 06, 2011 | Stanley Tr45 Sharpshooter Light Duty...
Just bought TR110 staple gun and no staples are firing out
check the spring,. also there must be something lodged in it... look closer..
Feb 13, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
Bostitch Mlll floor stapler drives a staple only on about every third try.
If the tool sounds like it is firing when its struck but its not driving staples, there may be a problem with the feed magazine. Possibly something stuck in the staple slot keeping them from sliding through. Or possible the pusher spring is weak. This spring feeds the staples into the unit.
Dec 26, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
Arrow staple gun will not shoot it seems it is locked into place
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Nov 23, 2010 | Arrow T50P ARROW STAPLE GUN
I have a Pro Sharp Shooter TR 200. WHILE I HAD TROUBLE loading the staples in, I think I have them in properly, the staple cartridge door is closed but the staples aren't coming out. What am I doing...
Make sure that you are using staples made for this tool. Remove the staples and look for a jammed staple at the drive head which will block further staple movement. Make sure there is spring tension at the rear of the staple row when the slide is closed. Hope this helps!
Oct 15, 2010 | Stanley Garden
My T50P will not discharge staples. I'm using the correct staples, there is no jam that I can see, and everything is well-lubed. It seems like the driver is not retracting far enough to allow a staple to...
sometimes mine won't shoot, and i find a single staple in the track, almost ready to fire out , but can't , they can be hard to see in the tract, i keep sharp pliers on hand to clear them. hope this helps
Sep 30, 2010 | Arrow T50P ARROW STAPLE GUN
Stanley sharp shooter tr110 staple gun. will not staple after loading. got ideas?
Are you loading it correctly? It took me awhile to figure it out myself. When you pull the clip out I was convinced you have to load them in there above where that black spring is on the slide lock that you pull out (as they seem to fit there) but no, you do have to turn it upside down to where the place where the staples shoot out is facing you and then load the staples into that space that you now see in front of you by placing the staples in upside down (pointy ends facing you). Then just slide the slide lock back over the staples you just placed in. I had to push down and then up on the clip to lock mine in all the way but some might lock in on their own (not sure). It should work fine from there.
Sep 27, 2010 | Powerfast Stanley TR110 Light-Duty Staple...
Stanley TR 250 Staple Gun Staple cartridge problem
very simple to fix it 1 pull the trigger all the way out 2 there is a little piece of metal, pull it all the way out (detach the piece out from the gun) an connect one side of the spring 3 push the piece back on the gun. 4 on the other side of the spring tide a little fishing line 5 pass the fishing line over a small rounded piece and pull it hard 6 finally connect the side of the spring onto a little hock on the base of the trigger
Mar 17, 2010 | Stanley Tools/Goldblatt Tool No.TR150 Hd...
Tools & Hardware - Others Logo
60 people viewed this question
Top Sharp Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Sharp Tool and Hardware - Other Expert? Answer questions, earn points and help others
