Question about Yamaha Music
How to replace the backlight on a yamaha PSR s700 keyboard
robocop
  • 90 Answers
SOURCE: Instruction manual for a Yamaha PSR 195 keyboard.
Try going to http://www.yamaha.co.jp/manual/english/index.php. There, you can try to find your owners manual for free.
Posted on Jan 22, 2009
SOURCE: Yamaha PSR-510 Keyboard
There is no need for a manual. It is so easy to operate because it is designed for easy opeating. If you need a manual to operate the PSR-510 then you really won't be able to operate it even after studying the manual. But here it is just in case you can by some miracle!
http://www2.yamaha.co.jp/manual/pdf/emi/english/port/PSR510E.pdf
Posted on Feb 10, 2009
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Posted on Feb 14, 2010
SOURCE: yamaha psr s900 screen/display gone bad
MR SATISH IF YOU WANT TO SOLVE THIS PROBLEM CONTACT:9887070565,94136768(ANAND NARWAL)FROM RAJPUTANA ENTERPRISES
Posted on Aug 07, 2010
  • 5603 Answers
SOURCE: i have yamaha PSR-i425 keyboard.can i conect it
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Posted on Sep 08, 2010
How do you replace a failed LCD backlight lamp on a Yamaha PSR-S700 keyboard? Is this a user or a workshop repair?
The backlight is not shown as a replaceable item only as part of the LCD unit. There is a complication in replacing the screen as the original screen is no longer available and a replacement screen also now involves other modifications beyond the average user I would suggest.
Speak to your local Yamaha dealer for a price on the screen kit
Oct 16, 2016 | Yamaha Music
Yamaha psr700 speaker cover removal
Assuming this is a PSR-S700 then you need to undo all the screws under the keyboard and open up so you can see inside under the speaker grill. You will see the grill has tabs that poke through the casing and these are then twisted to keep it in place. Straighten these, push tab through casing going from side to side and then the grill will eventually work free. You do not want to do this too much as the tabs will eventually break with wear.
Jun 18, 2016 | Yamaha PSR-S500 Digital Keyboard
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Psr s700 display has been changed colour blue then display is blinking what is the problem
change the whole screen the on capacitor 344 & 544 add resistor with value 2.2k, it will help your keyboard stay longer.
Aug 07, 2014 | Yamaha PSR-S700 ARRANGER WORKSTATION...
Yamaha PSR-S700 reset
Press the last note (right side) while powering your s700 ,this will reset your settings.
Jul 04, 2014 | Yamaha PSR-S700 ARRANGER WORKSTATION...
I have a Yamaha PSR S700 keyboard. Whenever I play it, the OTS settings automatically gets changed and disabling all my other buttons on panel. Only if I select 'No' for the question displayed in...
It sounds like one of the OTS buttons is getting triggered accidentally. There may be a build up of residue behind the button. With the unit off, try rapidly pressing the OTS buttons, one at a time. This should help to move any debris which may be creating a false contact.
If you are feeling brave, you can try opening the keyboard and getting inside, under the button with some electrical contact cleaner such as DeOxit or Servisol.But be warned: it can be difficult to get the parts back together properly! So if you don't have much servicing experience, call your local music shop to find a service technician.
Sep 19, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
I'VE A YAMAHA PSR S700. The problem is with it's screen. Whenever i start playing, the screen fades and then it comes and it goes and vice versa. This occurs almost two - three days a week. There...
Likely a connection to the backlight is being broken. Tap on the unoit and see if it pops back on. Illuminate screen with a flashlight and see if the characters can be seen when screen is faded. If they can, then the backlight is the problem... IF NOT then the display may be bad... This has been a problem and if you are under warranty, excersise it immediately... else replacement of the display is relatively expensive.
May 28, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
I have a Yamaha PSR-S700. Recently, the touch sensitivity in one of the keys stopped working. Very little pressure applied would cause the note to sound as if the touch sensitivity was off completely. Now...
You MAY be confusing touch sensitivity with VELOCITY sensing. Touch sensitivity is PRESSURE put on AFTER the note sounds that causes modulation. VELOCITY is what is used for example to control the loudness of pianoo notes depending how fast they are struck. VELOCITY sensing is done by using TWO contacts at every key... one closes first. IF one of these gets dirty, FULL velocity will be sensed and it will be LOUD. The contacts can be cleaned using ONLY 99% isoprophyl alcohol and Qtips after MUCH disassembly of the keyboard. The contacts are conductive rubber pills in silicone rubber domes. Clean boththe contacts and the circuit traces they pres down onto.
Apr 02, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
The keyboard is showing sign of power input but the screen is not lighting and produces no sound
1. Try the volume
2. Your adapter may not be the proper voltage/amperage. If the adapter has ratings listed, make sure they match the keyboards ratings.
3. Try it with the headphones. If they work and the speakers don't, you've narrowed down your problem. There may be some damage or wiring problem within where the board meets the speakers, and/or before processing.
4. Try it with batteries. If that works, you need a new adapter.
http://www.ioffer.com/i/adaptor-cord-yamaha-psr-or700-s500-s700-s900-arranger-113553507
Feb 06, 2011 | Yamaha PSR-S500 Digital Keyboard
Yamaha psr s900 screen/display gone bad
Jul 22, 2010 | Yamaha Full-Size Keyboard
Music Logo
32 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
