Question about The Computers & Internet
How do I open the Dixon mouse to insert the battery pls help.
5 Suggested Answers
scott201201
  • 170 Answers
SOURCE: Cannot open mouse to insert battery
http://www.logitech.com/index.cfm/keyboards/keyboard_mice_combos/devices/154&cl=roeu,en
Posted on Apr 09, 2008
  • 59 Answers
SOURCE: can't open my optical wireless mouse to insert new batteries.
usually on the bottom of the mouse there is a little door with two notches or a single vertical notch which you need to carefully pry open and then insert your batteries as shown inside with + and - denotions.
Posted on Jul 29, 2009
  • 72 Answers
SOURCE: how do I insert battery
on the bottom there is a small indentation which you can use your finger or thumb or small screwdriver to slide open revealing a space where the batteries are. Open and replace and close.
Please rate this answer. Thank you.
Posted on Mar 28, 2010
SOURCE: how to insert batteries in 99914 mouse
Well, whomever posted a solution was incorrect with my mouse. Right underneath the mouse cover there is a battery compartment, that holds the two batteries in place. To remove that cover you will need something to pry lightly on the lip clip pushing it forward toward the wheel. Remember just a little pressure otherwise you could damage said mouse. The clip is toward the back right above the batteries. good luck
Posted on May 07, 2013
How to insert batteries in 99914 mouse
Install the batteries (2 AA batteries) into the mouse. Locate the red laser light underneath the mouse. Next to the light, there is a small button that will require a small object, such as the end of a pen, to press. Press and hold this light for 3 seconds. You should observe several flashes of red light and then a steady red light when it is ready
Nov 19, 2011 | Computers & Internet
How do i open my logitech mouse to put batteries in?
Hi tg_sanford,
just look around the mouse if there are any switches that opens the mouse, this should be an easy task, once you found it insert the batteries and put the cover back on.
i hope this helps, good luck!
Mar 17, 2011 | Logitech Cordless Mouse
Only a few hours after inserting a new battery (tried two different packs of NEW batteries) into my Microsoft 6000 wireless mouse, the red light on top comes on.
I use rechargeable batteries rated at 3200MAh and have been operating for 2 months now.
If you can't get hold of them, try fresh Alkaline batteries like Duracell.
pls. vote for better service... thank you
Nov 14, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
How do I insert battery
Mar 28, 2010 | Targus Wireless Stow-N-Go Optical Laptop...
I cannot find a way to open the compartment to change battery in mouse. Have pressed button and pushed and pulled - nothing
This help?? >>>>>>>>>>>>>>>
Where do I change the batteries for my mouse? I can't find where the batteries go.
Answer
This article applies to the following products:
All Logitech cordless mice
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, replace the battery door.
Mar 28, 2010 | Logitech Cordless Mouse
Can't open my optical wireless mouse to insert new batteries.
Jul 29, 2009 | GE Wireless Optical Mouse
Need to insert battery to zippy's optical mouse
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Dec 05, 2008 | Zippy EL-610 Electron Luminescent Keyboard
ASpire 5580 series, no power
Hi Dhadha,
Try this: - remove AC adapter plug - remove the battery - insert the battery again. - try power up the laptop.
I have same problem, but this trick always work, and I always do this every power up. :)
However, I am using a usb optical mouse for an indicator. When inserting the battery, I check the light on the mouse. If it is flashing the second I insert the battery, then the power up will be successful. IF it is not, then remove and insert the battery again.
Try it.
Regards,
Dapid Candra
Nov 17, 2008 | Acer Aspire 5580 Notebook
Can't insert battery to the mouse
Aug 02, 2008 | Micro Innovations Micro Optical 3 Button...
Nov 09, 2007 | Logitech Cordless Desktop EX110
Computers & Internet Logo
71 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
