Question about Radio Communications
I attached the plug off an old pair of headphones too my p.a. speaker(phsp4), turned my cb radio to p.a. and heard nothing? Am I doing something wrong?
sandrew
  • 2961 Answers
SOURCE: Built-in speakers problem!
I dont think its a hardware problem, go to this site and go down to the XP drivers and download audio drivers and re install http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Apr 06, 2007
  • 44 Answers
SOURCE: No sound output from rear speaker jack
Plugging headphones into the computer will disable sound output from the sound card by design.
Posted on Sep 17, 2007
  • 5 Answers
SOURCE: The speakers don't work
Ok There is another chance to work your speakers ,
  If you have your mother board CD , get play that  and  reinstall the sound system .
  I hope it will work ,      please do reply
Posted on Dec 22, 2007
  • 24 Answers
SOURCE: audio out-jack doesn't work
There is a physical connection that shuts off the speakers when you insert the plug and push the connection open. It may be damaged or stuck. Probably need to open the unit to see. Did this connection used to work?
Don't force anything into the hole as this may already be the problem.
Posted on Apr 05, 2008
SOURCE: i have a yamaha rxv663
wireless speakers will usually hook to speaker outputs as well as headphone jacks. hook the wireless speakers up to speakers "b".
Posted on Dec 17, 2008
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
KENWOOD TS 450S WITH RX PROBLEM
If you are still seeing meter deflection in received signals, it sounds like something in the audio amplifier went south.
Apr 23, 2014 | Radio Communications
How to pair craig cma3532bt
To Pair:
1. Turn on your Bluetooth speaker/headphones (slide switch to BT)
2. Light should turn on Blue. If not, plug speaker into USB connector and light will turn Red to indicate it's charging.
3. Make sure Bluetooth is turned on your PC or Phone. Select device name: CMA3532BT.
4. Enter pairing code (passcode): 0000 or you can try: 1234
Jan 03, 2013 | Radio Communications
My cb radio is on but cant hear nothing sound is turn up but nothing come out
You didn't include the make / model CB you have, so I can only offer general suggestions. If these do not work, please provided the missing info.
Start out by locating and setting the the Volume to a position between 1/4 and 1/2 way clockwise, the Squelch to fully counter-clockwise and the "RF Gain" to fully clockwise to "MAX".
Check the position of the "PA / CB" switch and set to CB. When set to PA, both receive and transmit audio is sent directly to an outdoor speaker (instead of through the transmitter and antenna for reception by other radios). The PA speaker is usually connected to a jack at the rear of the radio. When the PA / CB switch is selected, the internal speaker is silenced even if there is no PA speaker connected.
At this point, you should hear static or voices (with an antenna connected). Do not attempt to transmit without a properly tuned antenna connected. If no sound is heard, there's something else wrong.
May 22, 2012 | Uniden Pc 78xl Cb Radio Mobile
I have a Uniden Pro 510xl, it's about 9 yrs old. I went to use it last week and after turning it on, found that there was no sound, (turned the squelch up) . When I keyed the mic, I saw that I was...
chk mic, lose cable in **** plug test with other mic .. also test with Ext speaker.. do u get any reading on meter / LED display during RX? does PA work? otherwise your sound chip is dead
Dec 30, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I have a Cobra ltd 25 classic in my pick up. the cb will turn on but i cant get any stacik no matter where i turn the squelch or rf gain. this doesnt seem right because it has never done that before. but...
Does the signal meter show any signal? Try plugging something into and out of the EXT Speaker jack to see if maybe that is preventing the internal speaker from working, or plug in an external speaker or headphone to test it. If the meter shows nothing, I'm concerned about your electronics, especially with the 'squelch' control 'wide-open'. 73's
Aug 13, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
I got a cobra 29classic cb, little hours. i have
Set the squelch and knob to full counter-clockwise position. Turn the volume up to the 1/2 way point. Disconnect the external speaker plug from the jack. Disconnect any PA speaker plug from jack. Static / voices should be heard from internal speaker. If not disconnect the mic. Static / voices should be heard. If not, tune a different channel, sound should be heard. if not, look for indication of the radio stuck in transmit mode. If in transmit, there will be no sound until you can stop transmitting (hopefully while connected to a 50 ohm dummy load or suitable antenna - otherwise the final transistors may be blown). Reconnect accessories to determine problem component.
Mar 12, 2010 | Radio Communications
White noise in left channel on my Vestax PMC 06 pro-a DJ mixer
try it with nothing plugged in to the inputs, if there is no noise. most likely its the turntable, cd player, or whatever the input is is the problem. or try plugging the mixer into a different area of the house/room. its like if you were to put your cell phone by a mixer, or speakers.
Jun 25, 2009 | Vestax Pmc07pro DJ Mixer System
I put the ear plugs in and nothing happens.. not
To get the basics out of the way, is the volume turned up and not muted at all... if it's turned up then try another pair of headphones that you know work in something else or test these headphones in something else...( cd player, radio etc.) use a pair that you know work to retest your mp3. plug them in, turn it on and play a song the gently wiggle the end plugged into the player back and forth. If you hear a crackling or snippets of song, then it's probably the jack inside the player....try these things and get back.
PS. post the make and model of your player, it helps with problem identification
Feb 20, 2009 | Coby MP-C883 MP3 Player
Radio Communications Logo
21 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
