Question about Garden
Im having trouble keeping my MT WIZARD riding lawn mower running. It will start and I can mow for a few minutes and then it shuts off and won't restart without a jump
  • 246 Answers
SOURCE: I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>2- .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
jbridger (John)
Posted on May 17, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
  • 413 Answers
SOURCE: engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
Posted on May 29, 2009
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Posted on May 30, 2009
  • 28 Answers
SOURCE: I have a Murray riding lawn mower Model 425600x8A.
The oil entered the cyliders when the mower was tipped at a severe angle. It will clear out after you run it for awhile. Check the oil level to make sure it is full. It could even be overfull and this is what caused the smoke. If it starts to run badly, check the spark plug or plugs. They could get "fouled" from the oil. Change the if the are black or covered with oil. It shouldn't have done any damage to the engine.
Posted on Jun 24, 2009
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
Masport 4 stroke mower...started it up and it worked for a couple minutes with a strange rattling growling noise.. Oil ok and petrol filled but the mower just shut it's self down and im not sure w
It will run for a few minutes and then shut down?
Lets ignore the growl for now. Loosen Gas cap and see if it will keep running. The rattle might be in the pull cord mechanism..possibly not related to stalling issue
Dec 03, 2012 | Garden
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
1872 cub cadet. Pto keeps turning off. Will mow a few minutes then blades shut off
Check your battery posts and terminals, they may be corroded, or your battery may be dying.
Jul 15, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
PTO red light switch is on when PTO isn't, so engine won't start
Mitch...the reverse safety switch, I beieve, is designed to kill both the motor and the blades if you don't use the override button prior to trying to mow in reverse. Since I don't know the make or model of your tractor, your not wise to reverse mow unless the override switch is engaged....hope this helps..
Jun 06, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
