Question about Diamond Computers & Internet
MEDIAN DIAMOND CATCHER LI - Diamond Computers & Internet
What's the meaning of media in math?
  1. The median is also the number that is halfway into the set. To find themedian, the data should first be arranged in order from least to greatest. To remember the definition of a median, just think of the median of a road, which is the middlemost part of the road.
  2. The Median of a Set of Data - Math Goodies
    www.mathgoodies.com/lessons/vol8/median.html
Sep 17, 2015 | Mathsoft StudyWorks! Middle School Deluxe...
What is the median math deffinition
middle number
To find the Median, place the numbers you are given in value order and find the middle number. Example: find the Median of {13, 23, 11, 16, 15, 10, 26}. Put them in order: {10, 11, 13, 15, 16, 23, 26} The middle number is 15, so the median is 15. (If there are two middle numbers, you average them.)
Mar 04, 2015 | Computers & Internet
Mean, median, mode
Mean= average =(sum of data values)/(number of data values)
Mode is the most frequent data value.
Median: Sort the data in ascending order. The element in the middle is the median.
If the number of data is odd, there will be one MIDDLE element. It is the median.
If the number of data is even, there will be two elements in the middle. Add the values of these middle elements and divide by 2. The result will be the median. It is not part of the data.
Apr 22, 2014 | Texas Instruments TI-34II Explorer Plus...
TI-34 mean, median, mode
Apr 22, 2014 | Texas Instruments TI-34 Scientific...
Math mean median mode
Mean, median, mode
You don't need the calculator for that. Sort the data in ascending order.
Mode
Find the most frequent data element (the one repeated the most) in the set. That is the mode. If you have several elements that share the same highest frequency all of them are modes.
Median
Count the number of elements in the set.
If the number of elements is ODD the median is the element that happens to hold the middle place in the ordered set.
If the number of data elements is EVEN, then there is not one middle element, but 2. Call them if you wish MIDLeft, and MIDRight
Take the values of these two elements and calculate their average.
Median_value =(MIDLeft+MIDRight)/2
That average is the value of the median.
You can imagine the median as a virtual (not really there) data element inserted between the two middle elements and having as value the average of the two middle elements
Your set would look like the following
{Min_value, ..., MIDLeft_value, Median_value, MIDRight_value, ..., Max_value}
Now, was there something about fractions?
Dec 18, 2013 | Computers & Internet
Median and mode
Order the data in ascending order.
Mode
Median
Dec 08, 2013 | Sharp EL-2630P Calculator
Whats a median
The median of a finite list of numbers can be found by arranging all the observations from lowest value to highest value and picking the middle one (e.g., the median of {3, 5, 9} is 5). If there is an even number of observations, then there is no single middle value; the median is then usually defined to be the mean of the two middle values. It is similar to an average. or a root mean square value (RMS).
Nov 30, 2013 | Computers & Internet
The question is incomplete.
The mean, also called the average is defined as
mean= (sum of the data values)/(number of data elements)
Mode = the most frequent data value (the one that is most repeated)
To find the median:
  1. Order the data values in ascending order (sort them from the smallestr to the largest), and
  2. Locate the data value that is in the middle.
  3. If the number of data values id ODD (not a multiple of 2) there is only one middle element. That is the median.
  4. If the number of data elements is EVEN (multiple of 2), there is not one middle element but two.
  5. The median is the average of the two middle element values
    1. Median =( left of middle value +right of middle value)/2
    2. Imagine this median value to be inserted between the two middle elements
Example 1
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20)/9=?
Mode= most frequent value. Here it is 13 (repeated 3 times)
There are 9 values, an odd number. Middle element is the 5th ( 13.5)
Median=13.5
Example 2
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20, 25
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20 + 25)/10=?
There are 10 values, an even number. Middle element is not among the values. There are two middle elements (the 5th and the 6th) or
The value of the median is the average of the 5th and 6th elements or
Value of Median =(13.5+14)/2=?
Nov 21, 2013 | Computers & Internet
Can you use a Casio fx-115ES to find the median?
If you have a large data set, use excel or some other program for finding the median of a large set of numbers. Otherwise, go back to the definition of median, the number in the middle if you line them up from lowest to highest in numerical order and write them out and find it. e.g. the median of 2,5,4,1, and 7 is 4 because if they are placed in numerical order (1,2,4,5,7) "4" happens to be in the middle.
Mar 11, 2011 | Casio FX-115ES Scientific Calculator
Computers & Internet Logo
48 people viewed this question
Top Diamond Computers & Internet Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Diamond Computer and Internet Expert? Answer questions, earn points and help others
