Question about Refrigerators
Error code E ref , rF freezer - Refrigerators
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
Kenmore elite bottom freezer refridegerator error code er rf
you could call a repairman but if it is fairly old then buy a new smaller refrigerator the smaller simple ones seem to last longer in the long run .
Jul 17, 2015 | Kenmore Refrigerators
What is wrong when I receive error code Er rF
Hello Anonymous!
Error code Er rF is an :Abnormality of BLDC FAN Motor for Freezer.
  • The freezer fan motor may be Defective.
  • Unplug the fridge for about 30 minutes and plug it back in, if the code appear again within 24 Hr , the Main Board might be defective too.
  • Check if the freezer fan is blowing normally, then the Main board has a problem.
  • If not, the Fan Motor is defective or both.
  • I would change the Fan first then the Main PCB
Good Luck,
JP
Jul 09, 2015 | LG Stainless Steel French Door...
OP ERROR CODE FOR ELECTROLUX REF
Hello scarter517 - Typically error code OP indicates that the freezer sensor is in an open position. A professional would need to check the wiring between the thermistor and board. If correct, the thermistor may possibly need replacing.
Nov 20, 2012 | Washing Machines
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
