Question about Honda Electrical Supplies
Honda eg 550 generator starts but if i conect the plug from astatior the motor labour
4 Suggested Answers
mmcgow1636
  • 3 Answers
SOURCE: 30 volts coming out of generator
sounds to me like a grounding issue. I would check all my ground paths and look for poor connection or corroded contacts, broken or almost broken wires etc. Hope this helps :)
Posted on May 27, 2009
buffalonyman
  • 1865 Answers
SOURCE: Honda EG 2200 Generator wont Start
First make sure that you have a spark; remove the spark plug and position it so that the threads are touching the engine frame. Pull the cord and check the plug for spark. If you have spark, put the plug back in.
Get some starting fluid and spray it into the air intake of the carbuerator. Try to start the engine. If it starts and then stops, that indicates that you have a fuel delivery problem. Clean the fuel filter.
Posted on May 31, 2009
emissionwiz
  • 80417 Answers
SOURCE: honda. eg550 generator
I would say the AC is overloading the Generator. AC units require ALLOT OF POWER.
Posted on May 16, 2017
Honda generator not producing electrical current
Generators rely on a residual magnetic field to "kick start" the current making process. Yours has lost this field. Easy enough to fix however.
Plug in an electric drill while it's running. Squeeze the trigger and manually twist the end of the drill (this will act as a miniature generator, as the Honda has lost its magnetic permeability and this motor rotating in reverse will generate a small current and restore it). Take care as, as soon as you spin it fast enough to develop a current, the generator will pick up on this current and start generating it's own current; energizing the drill. Once the generator starts generating current, it will repair itself.
Dec 25, 2017 | Honda Electrical Supplies
Electric starter will not work on honda e u 3000 generator
Hi there! 1) Check battery with a load tester and recharge / replace if necessary 2) Check the ignition switch for loose wires or if the switch is okay 3) Remove the starter and try to run it against a piece of wood ( Have you seen the wooden hammer handle of an auto electrician?) If you can stop it then the motor needs repair/replacement it is often cheaper to replace than repair it excluding labour!! 4) Check ringear on the flywheel and the pinnion of the starter motor for binding and wear. Keep these tips in mind for your Automobiles too
Jul 25, 2016 | Honda Electrical Supplies
I HAVE A GENERATOR HONDA E2500.
the generator is not big enough to run what you want
it needs to be 3500w minimum or 4.5w to be safe
although it is stated at 2500 watts , in fact that is the peak load on electric motor start up and its continuous rating will be around 1.8 watts
all of this is clearly stated on the specs plate on the generator
Dec 06, 2015 | Honda Generator E2500 Vintage Great...
My Honda E X 5.500 ,5.5 KVA GENERATOR will start but not put out any power
Have you checked the output with a VOM, or just plugged in a tool, light etc?
Aug 01, 2014 | Electrical Supplies
Why is spark plug breaking down on new honda generator 3000?
If the plug isn't fouled and looks all right, it could be the resistor cap on the plug wire. It could also be a warning from the CDI that it is giving up the ghost.
Jul 05, 2014 | Honda 3000 Watt Portable Generator
My honda cbx 550 f2 will not start no spark at the plugs
Greetings from Bermagui have you checked either the cdi unit or the coil pack? they made need replacing good luck 7 let me know how you got on
cheers
Nov 03, 2010 | 1983 Honda CBX 550 F-F2
Powerboss 6500 won't run tools
powerboss generator wont start,,fresh fuel,fire to plug,clean float bowl,,,,,,honda gtx 390 motor,,,,13 hp,,,help
Oct 14, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
1994 honda cbr 600 motorcycle wont start just turns over put new petrol and replaced plugs but still wont start please help
check pulse generator circuit for any opens or shorts..even if you still show a weak purplish/red spark its bad..it must be a big bluish/white spark..check plug #1 for spark and then check #3 foe spark if there both week then its your pulse generators that are bad ..but if one of them has a blushish spark then it that systems coil..eg #1and#4 or the #2and #3 coils..
Aug 19, 2010 | 1994 Honda CBR 600 F(2)R
May 31, 2009 | Honda Electrical Supplies
May 19, 2009 | McCulloch 3500-Watt Gas Generator #...
Electrical Supplies Logo
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
