Question about Cameras
SD card remove card protected? - Cameras
  • Cameras Master
  • 5,375 Answers
Unset write protect on the card.
Posted on May 16, 2017
Remove write protection on sd card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 18, 2014 | Electronics - Others
Tip
SD Card Write Protect
Good day,
This tip will explain how to remove the write protect from your SD Card.
This is a easy fix and won't take a minute.
First remove your SD Card from your device. You will see on the side of the SD Card that there is a small switch. If your SD Card complains about being write protected simply put the switch in the opposite position. Some of the SD Cards even have the word LOCK on near the switch indicating the direction the switch must be to LOCK the card.
Once the switch is changed you can put the SD Card back into your device and the problem of write protection would be solved.
Please feel free to let me know if this tip was able to help you!
Regards
on Nov 29, 2010 | Cameras
How do i remove the write protection on my galaxy s sd card
need to remove the write protection from the PHONE MEMORY so i cant delete anything . remove-write-protection-galaxy-s-sd-card-0mcgnre0akckbqsgiub3i30g-3-0.png
kindiy anybody help on this
May 25, 2012 | Samsung Galaxy S 4G Cell Phone
Removing write-protection from SD card
May 02, 2012 | SanDisk Microsd 2gb Memory Card Micro Sd 2...
I PURCHASED A KINGSTON MMC MOBILE SD CARD, AND INSERTED INTO THE SLOT OF MY PHONE AND WAS NOT ABLE STORED ANY DATA ON IT, SUGGESTING THAT MAY BE THERE IS A LITTLE PROBLEM WITH MY PHONE, SO I DECIDED TO...
SD cards allow you to store digital information; you can use SD cards with most electronic devices like digital cameras and computers.
An SD card will become write protected if the switch on the card is placed on the "Lock" position. This prevents any information on the card from being altered or deleted.
If you wish to add, delete or change any of the information, you must remove the write protection.
Remove the SD card from the computer or digital device.
Locate a switch on the bottom or side of the SD card.
Move the switch to the "Unlocked" position to remove the write protection.
If you do not have a switch, you will need to remove the write protection with your computer.
Insert the SD card into your computer's card reader or back into the digital device.
You can now save and change information on the card.
Apr 07, 2011 | Kingston 1 GB microSD Card with USB 20...
How do i take write protect off?
Good day,
Regards
Apr 04, 2011 | Olympus ? 1030SW Digital Camera
How to remove the write protected micro sd card?
Dec 06, 2010 | Kingston 1 GB microSD Card with USB 20...
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
Remove write protection from micro-sd card
  1. Remove the Sandisk SD card from your portable electronic device. Ensure that the SD card can be safely ejected before removing.
  2. Locate the write protect lock. The write protect lock should be on the side opposite the cut-off corner of the SD Card.
  3. Disengage the write protect lock. To do this, gently slide the small switch upward, toward the top of the SD Card. The card should now have write protection disabled.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Mar 03, 2010 | SanDisk 2GB microSD Memory Card
Write protection problem of my mobile memory card
Hi..
To remove the right protection it is very simple, first remove your SD card in your mobile, the observe your SD card back to back, if you can see a small button you need to slide that button to remove right protection, then plug your SD card back to your china mobile and try to copay a folder,
Good luck !!!
Regards
PCmania
Jul 11, 2009 | Nokia N72 Cellular Phone
Cameras Logo
4,231 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
