Question about Golf
1984 gas ezgo golf cart.Replaced coil,plug wire and plug.Still no spark.Can you help me out with suggestions Thank you much
  • 1,162 Answers
Have you checked to see if the flywheel keyway is broken off or shifted? Have you set the magneto correctly, also does your engine use points. If not you should change it out to a newer electronic one, not expensive at all.
Posted on Jul 24, 2017
SOURCE: I ned a service manual for a 1995 ezgo dcs golf
Our EZ GO golf cart will start and run except you have to hold the choke about half way out for
it to continue to run. What is wrong?
Posted on Apr 20, 2009
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Posted on Aug 19, 2009
  • 34 Answers
SOURCE: I need a wiring diagram for a 1986 ezgo golf cart,
use this link http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?func=show&file=200332&Category=100013&Page=1
Posted on Apr 21, 2010
  • 34 Answers
SOURCE: club car golf cart intermittent no spark
What you have is a bad ignitor. It is a small part located behind the RPM limiter. Getting to it is a little tricky but I will try to explain. On the front of the motor, you will find 2 10mm bolts holding a black object that is the RPM limiter. Take these two bolts out and you will find the silver part behind the black box. It will have one wire running to it. The reason it is intermittent, is that heat from the engine builds up and the heat causes it to be bad. When it cools down, it will go to running again. The part runs about $50-$70 . Replace and make sure the connection fits snugly and that the wire that was under one of the bolts goes back on.
Posted on Apr 22, 2010
  • 34 Answers
SOURCE: EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Posted on Apr 24, 2010
Looking for wiring diagram for 1999 TXT EZGO golf cart controller?
There are a ton of them available, apparently:
https://www.google.com/search?q=1999+TXT+EZGO+golf+cart+controller&oq=1999+TXT+EZGO+golf+cart+controller&aqs=chrome..69i57.1143j0j4&sourceid=chrome&ie=UTF-8
Aug 02, 2017 | Golf
Ezgo golf cart 2001 model turns over but will not start. put in new battery and fresh gas. any ideas?
See if the spark plug is firing. If not then you looking at ignition coil or a ground being where it's not supposed to be. If it is firing then look at fuel pump, carb, air hose.
Jul 28, 2017 | Golf
Wheres the ground go on healights on a ezgo 3 wheeler
Never had a ezgo 3 wheeler to work on before but sounds interesting. If this is an electric cart then wire ground to a negative battery that gives 12 volts from where positive is connected. If gas cart wire to frame or neg post of battery.
Mar 28, 2017 | Golf
We have a 1999 gas club car golf cart just replaced the ignition coil. It now won't turn off
You need to run a wire to the coil from the hot wire coming from your key/ignition switch. This will ground the coil and eliminate the spark.
Sep 02, 2016 | Golf
I recently came across an ezgo golf cart I noticed I m leaking gas out of the petcock valve and was wondering if I can bypass it?
Hi, Sally I would "NOT" recommend bypassing the valve just replace it for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Product Manuals
GO Golf Cart Parts
Cartaholics Golf Cart Forum EZGO Golf Cart Repair
http://www.buggiesgonewild.com/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 09, 2016 | GAS Motorcycles
1990 ezgo gas golf cart no spark
At that age..cud b bad plug wire..plug..magneto..inspect entire ign n chargn system..utube or library help alot
Oct 05, 2015 | Cars & Trucks
Ez golf cart when I go up steep hill the cart loose power and smoke White smoke
Basic EZGO Golf Cart Problems And How To Fix -
www.golfcarthotrod.com > Golf Cart Repair
Apr 30, 2010 - Electric E-Z-Go Golf Carts are becoming more popular every day ..... I have a ezgo carryall gas golfcart. it has began to pour smoke from rear.
Aug 02, 2015 | Cars & Trucks
Cant get my gas powered ezgo golf cart to go up
Itsounds like you're not getting enough fuel to the cart. Then again your drive belt may be slipping which is not allowing the centrifugal clutch to move your car up hill. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Oct 13, 2014 | Golf
Yamaha 4 stroke golf cart back fires all the time..Replaced coils and the carby but no change
Very important... valves get out of adjustment and are easy to set. This is where I would start FOR SURE. Check out www.buggiesgonewild.com and an example of how to do it on EZ GO 295 http://www.buggiesgonewild.com/ezgo-gas-tech/1196-ezgo-295-350-engine-valve-adjustment.html
Apr 05, 2010 | 1981 Yamaha XJ 650
Golf Logo
425 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
