I want help on how to repair it
It stops while playing and even if you switch off and on again it works for seconds and stops
Why does my vcr plays for 4 seconds then stops please help
This probably indicates some kind of mechanism damage. Also the Mode Switch could be faulty or out place, again that can be caused by damage to the mechanical parts. The mode switch tells the electronics what position or playing mode the mechanism is in. Any incorrect movement results in stopping the actions and could result in system shutdown to prevent even more damage.
Aug 10, 2014 | Panasonic Televison & Video
Washer only works20 seconds then stops
Maybe at 10 years+ of service it is time to stop dumping money into repairs and buy a replacement.
Mar 14, 2017 | Roper Washing Machines
Buffering
Try switching off the router leave it for a couple of minutes and then let it restart usually works on talktalk
Sep 25, 2012 | Toshiba Computers & Internet
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
Changer will pick up CD and spin for about three seconds stop, set still for about four seconds. CD will not spin again reject CD back into the rack. the above will happen again but during the four second...
This sounds like an issue with either your CD player, CD control board, or Selection and Credit Computer. I can help you troubleshoot further over the phone (and repair/replace whatever is necessary). My name is Rod and I can be reached at tech@wurlitzer-ohio.com. Please email me and I'll email you my telephone number.
Jun 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
Roper electric range non stop beeping!
I'm thinking a door switch problem and/or maybe an intermittent keypad connection. Failing that, the electronic control may have failed. We repair oven controls at www.fixyourboard.com.
Sep 30, 2009 | Roper FEP320 Electric Kitchen Range
Cd's player wont work quite right
u need to manually clean the lens using cotton buds(no fluid or solution) extra care! hope this help u...
May 15, 2007 | Jensen MP5610 CD Player
Need help with my iriver ifp799 doesnt turn on
cajunito,
After more than 4 years of everyday use, mine stopped as well. The problem was that the [Play] button/switch soldering dislodged from the PCB. I opened the player and resoldered the [start/play/stop/off] switch back on the PCB. It now works again. I noticed the problem because I could still get the player to operate by using more force and put some side pressure on the switch, which apparently pushed the switch and the PCB together to make contact again.
With a problem like you have there can be many different causes, so this might not be your solution.
Regards,
Robert Ilbrink
Sep 03, 2006 | iRiver iFP-799 MP3 Player
 Grubhead
Grubhead
