Sorry, that last question should read ,hdd and not ,had,
Please enter built in HDD user password i forgot the password in lenovo Y500 model plz tell me solution
The HDD password ensures that no data can be read or used. Unfortunately, there is no legal way of cracking the code. Sorry.
Sep 30, 2013 | Amstron Lenovo 3000 Y500 Laptop AC Power...
Hi there! Yesterday I was installing Windows XP
Sorry to hear your having issues installing the OS.
There is two problems your facing one is the disk is so scratched that the system can not read the disk or the hard drive has bad sectors or clusters which are failing when being written to.
You have two options to fix this one is to make sure the cd is clean an or replace your hard drive.
General disk read error message tend to be from hard drive cylinder's.
Nov 05, 2010 | ASUS Computers & Internet
E-Machines T2642 PC Desktop from mother board 3 cables came unplugged 1 is green pwr led 1 is pwr s/w-black ,one is red hdd led i just need to know what order to plug them back in
Sorry you are having trouble.
Led's have a + and a - side.
With a magnifying glass you should be able to see where each one goes on the board. Start with pwr s/w. when you have it on the right pins then you can push the button and turn it on. I have done with with a screwdriver and quickly touching two pins at a time until it comes on.
Next the power LED. This one should be on all the time.
Last id hdd LED. This one will only be on when HDD is active and reading or writing.
The connector you are looking for is normally in the right hand corner opposite the power supply and has all the wires from the case going to it.
Apr 05, 2010 | E-Machines T2642 PC Desktop
My Toshiba external hard drive powers up but my Toshiba laptop doesn't read it. The blue powr light is on and the rive makes a clicking noise. HELP!
Hello there...
Looks like your HDD is having mechanical problem, this could happen due to a shock (dropped or bumped maybe?) which can cause your HDD I/O head loose from its track.
I'm sorry but my advice is prepare a HDD replacement.
hope that helps... :D
Jan 31, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
What is the normal noise for Samsung HDD
You should hear a low humming and some electronic beeping. If you're hearing a mechanical clicking or clinging or anything that sounds like metal bumping around in there, it's toast. I'm sorry but there are not mechanical parts in there, just electric motors, electromagnetic actuators and circuitry. While it's off, shake it. If you hear something rattling around, I'm sorry to say that it's done. Does it still work? what are you trying to accomplish?
Jan 18, 2010 | Samsung (SP0822N) 80 GB Hard Drive
Wrench icon 350e
The HDD control board does not generate any response when the IPU sends a
read/write signal to the MSU.
• Software defective
• Poor connection between BICU and MSU
• HDD defective.
Try reset the software; press the keys numeral and point simultaneously by but of 10 seconds, the machine is extinguished and returned to ignite. If it does not react to this it can be damaged the hard disk changes it.
Jul 27, 2009 | Ricoh Aficio 350e Printer
No HDD activity and blank screen
unfortunately i have to say yes it is time to get a new machine. That is unless you want to take it to a repair shop and have them look at it. Whatever it is it is definately hardware and yes i do believe it is the cpu which cannot be changed most of the time in notebooks. The graphics however may be expandable but i cannot tell you about your machine. You can find this by reading any material that came with the computer or by contacting the manufacturer. Sorry for the bad news but please don't forget to rate my response.
Jan 08, 2009 | Acer TravelMate 2303WLCi Notebook
Connection to Motherboard P4IBMS
You can download a PDF of the manual here:
http://www.ecsusa.com/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=74&areaid=2&LanID=9
I have blown up the image for you to see it easier:
good luck
steven
Sep 17, 2008 | Computers & Internet
Hdd
Then that means that you have to use software that can retrieve it. You can use this although its not free. Sorry
http://www.recovermyfiles.com/
Sep 09, 2008 | Computers & Internet
Hdd maxtor
Sorry about that last link. Go here..
http://www.maxtor-hdd.narod.ru/
Navigate to the larger chart in this page, and select the third link on the list. If you read across, it identifies itself as the hard drive you mentioned - Calypso family, 80GB.
That will get you what you need.
Apr 09, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
