Question about Acer Computers & Internet
How do I copy Acer hdd to a hard drive enclosure
Beni S-P
  • 1006 Answers
SOURCE: Enclosures for Seagate ST910021AS
Just buy an external
Posted on Nov 02, 2007
  • 1019 Answers
SOURCE: PS2 HDD Partition Error
A Partition error is the amount of segments that the hard-drive is split into.
For example we have 1 hard-drive Named C:/ Which Is 20 gigabytes. Then we decide that we want to use A Quarter of that drive, solely for saving games On. So 5 gigabytes Will Now Be allocated For Game-saves, This Will be known as Partition 2 Or D:/ So we now have 2 Partitions 1 is C:/ And 1 Is D:/ Partition C:/ is Currently 15 Gigabytes, And Partition D:/ is 5 Gigabytes.
Making a total Of 20 Gigabytes. So if your getting a partition error, it,s either because the game your attempting to transfer Is larger than the Partition, thats trying to receive it. You may be sending 4 gig to a 3.5 gig partition. Or your attempting to send it to a partition that is incorrect or inadequately lettered/numbered.
I hope this enables you to understand, the basics of Partitions on drives.
Mike @ Compurepair.
Posted on Mar 07, 2008
ninexunix
  • 64 Answers
SOURCE: Copying games from PS2HDD to PS2 HDD using enclosure
Yep, the program you want is called WinHiip (easily googleable) Its a special program that reads PS2 Hard Drives only. DO KEEP IN MIND: you must have either an enclosure or put it on the IDE/SATA cable on your computer so your BIOS will detect it. WINDOWS WILL NOT DETECT THESE PS2 FORMATTED HARD DRIVES. However that does not matter, as long as your BIOS sees it. If your bios sees it, all is good, boot into windows and load WinHIIP. It will detect it. If you're using an enclosure then it really doesn't matter. Plug that into your USB port and turn it on. Your plug and play will recognize the enclosure. After windows sees it turn on WinHIIP and choose the "Select Drive" button and you should see your hard drive in the list. Then it's just a matter of choosing the "Copy Drive" option. Or take each out by it's own. Meaning "Extract Image/s" This will save them as ISO's on your computer then you just pop in your new drive and turn on WinHiip again and "add images" Back onto the new hard drive.
Posted on Jun 08, 2008
Chinthakaj
  • 416 Answers
SOURCE: Can't open hard drive enclosure
A Details Guide too remove the Disk.
http://www.gearhack.com/myink/ViewPage.php?file=docs/AcomData%20E5%20HybridDrive%20External%20Hard%20Drive%20Disassembly
Posted on Feb 02, 2009
Geekman
  • 32281 Answers
SOURCE: Samsung sp0802n HDD enclosure. I installed
Has the hard drive been formated?
To format the drive, plug the external drive into the USB port - go to the Control Panel - Administrative Tools - Computer Management - Storage - Disk Management. The External drive should be listed as USB drive. On the lower panel, right click on the USB Drive and click on Format, and format it in NTFS.
After formating you will be able to use it as a normal hard drive.
Posted on Aug 01, 2009
I am a complete novice, can you help me please? I have purchased a 3.5 SATA/IDE back up enclosure to transfer files from old to new desktop. I have removed frame holding old harddrive into tower but cannot...
You want to remove the hard disk from old computer, connect it to the enclosure, and connect it externally to the new computer, right?
Now you have a problem connecting hard disk to the enclosure.
Usually there are no SATA/IDE enclosures. They are either IDE or SATA.
If the data connector in the hard disk (HDD) is rectangular with around 40 pins inside, it is an IDE HDD. Else if it has L shaped horizontal connector, it is a SATA HDD.
I suggest you to take the hard disk to the store and ask for a matching enclosure. If you bought the wrong one, they might replace it with the correct one.
If you feel you want to do it yourself, let us know. However an IDE HDD cannot be connected to a SATA enclosure and vise versa.
I sincerely hope you will get to copy the required files to your new computer. However before copying, it is better to install a reliable virus guard.
Sep 14, 2011 | Computers & Internet
I have the imicro 3.5"
the hdd enclose may be bad/faulty
try connecting the hard drive inside your computer doing away with the hdd enclosure
the light only means its getting power not a connection to hdd
hope this helps
Dec 15, 2010 | Western Digital imicro IM35ST320SI 3.5 IDE...
Computer doesnt pick up a usb
Remove the HDD from the enclosure and slave it inside your PC...if it reads it will be the enclosure is faulty. If still no read is faulty HDD.
Oct 16, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
My western digital green caviar hard drive doesn't seem to work i placed is on my enclosure and the disk drive doesn't spin i placed another hdd in my enclosure and it works just fine if there's something...
There are several Drive Transfer programs out there or cloning programs at Office Max, Best Buy, Target or Walmart that will copy the data from one drive to another. You should be able to connect a replacement drive in the chain and copy the drive using one of these or using the copy command. When you first start you will want to make sure you have the drive's set as slave and master correctly so the computer can recognize them in the proper order.
Jun 18, 2010 | Computers & Internet
Dead processor. good hard drive
get external hard drive shell, place the hard drive in it, the connect via firewire or usb all your info should be intact except if its a crash
Mar 23, 2010 | IBM ThinkCentre A50 PC Desktop
Hdd won't go into right size hdd enclosure case
Hi there
Sorry to say that you need to return your drive to your supplier !
you have purchased a Sata HDD and the one you require is an ide hdd
Regards
Al "alstech"
May 25, 2009 | i-rocks IR-9200 USB 2.0 2.5" HDD Enclosure...
How can i make my seagate hard disk an usb hard
It is quite easy, do not worry.
You only need to bought and USB enclosure, here is a link to many products on ebay
http://search.ebay.com/search/search.dll?from=R40&_trksid=p0.m37.l1313&satitle=hard+drive+enclosure+usb&category0=
then you have to connect your hard drive inside the enclosure and the enclosure to your computer using the usb cable and that's it.
Just be carefull about the enclosure, I guess it is a Hard drive from a desktop, is in it? because some enclosure are for laptop's hard drive.
Also you need to know if your hard drive is SATA or IDE, IDE is the normal gray bus cable with fourty some pins, and the SATA it is a really small cable (I do not use technicims to not confuse you even more).
Also, there are some adapters from IDE/SATA to USB that you can buy in your local computer store (do not go to bestbuy, compusa, ... they only sell external hd), or also get it from ebay.
The only diference between the enclosure and the adapter is that the enclosure looks better :D, and the adapter is just a bunch of cables.
Mar 19, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
My computer crash and I need to transfer my desktop hard drive info to my laptop hard drive
install the HDD to other desktop and grab the files or if you can buy USB interface to your hard drive like hard drive enclosure. then you can connect the hard drive to your laptop
Mar 13, 2009 | Dell OptiPlex GX270 PC Desktop
BURNED CKT
If it is the USB adapter that is part of the enclosure, (not the disk itself) you can transfer the HDD that is inside this enclosure into a generic external HDD enclosure. either that or you can use an external HDD adapter to access the data on a disk (like Magic Bridge), this is and adapter without the enclosure, and is fairly handy if you need to get data from HDD in this way.. or to Clone disks
Nov 02, 2007 | Maxtor OneTouch II 300 GB Hard Drive
Computers & Internet Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
