Question about The Watches
Uniden 6.0 dect messege light will not stop blinking
If you press & holdhold the find button it stops until you get a call or call someone it starts again
    Renaissance:
    An user who is expert in 3 categories / brands.
  • The Master
  • 575 Answers
Resetting the voice message indicator
if the voice message indicator icon remains after you check your messages , you can reset it
1---with the phone in standby, open the menu
2 select the global setup, then select the VMWI reset
3 select yes
Posted on May 18, 2017
Testimonial: "masud i have glogal setup DO NOT HAVE VMWI"
    Top Expert:
  • The Master
  • 47,705 Answers
3 select yes
the flashing light will then go to full on as in the phone standby situation
refeence from the uniden user manual
Posted on May 16, 2017
Testimonial: "i donot have a global setup"
  • 2 more comments
  • Anonymous May 16, 2017
    i found the global setup cannot find VMWI I HAVE AREA CODE DIAL MODES SET LINE MODE THATS IT THANK YOU
  • Bill Boyd May 17, 2017
    if you have found global set up , scroll around to find the vmwi wording and change from no to yes
  • Anonymous May 17, 2017
    there is no vmwi thanks for all your help
    i looked in my users guide there is no vmwi it has only 3 settings for global set up and i told you what those are thanks again
I cant set the time on my adidas duramo watch. It says 'offset' and below it says '1H'
This has already been posted on Fixya, so I take no credit for it. I've put the original reply below :-
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
Aug 31, 2017 | Adidas Watches
Set time on adidas Adults' Performance Duramo Watch
Mar 15, 2012 | Adidas Watches
How to set time for aquastar N0 4095
When looking at the face, you have 4 pushers. Top left is for regatta function countdown. Top right is regatta function start-stop-reset. Bottom left is Hours-Minutes and Nite Lite. Bottom right is regatta function "catch up". Assuming that you want to set Hours and Minutes, press and hold the bottom left for 3 seconds...Hours will start blinking, press the pusher successively until the desired hour is reached. Then wait until it stops blinking. To set minutes, press and hold for 3 seconds, the hours will again begin to blink, then release and re-press for an additional 3 seconds and the minutes will blink, Then press successively until desired minutes have been reached. Stop pressing and wait until the blinking has stopped. Once it has stopped blinking your time has been successfully registered. Good Luck. Hope this helps!
Nov 02, 2009 | Watches
Does anyone have instructions for Nike Imara Fit WR0076?
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
May 13, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
How do I set the time for nike imara fit WR0076-002 wrist watch?
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Mar 26, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
I dont know how to set the time
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Nov 11, 2008 | Nike Imara Run WR0075-014 Wrist Watch
Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
Nov 11, 2008 | Nike Imara Soar WR0103 201 wristwatch
Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
Oct 21, 2008 | Casio Watches
Timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Mar 09, 2008 | Timex 1440 Nylon watch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Watches Logo
Top The Watches Experts
D. E. Hev
John mullen
Are you a The Watch Expert? Answer questions, earn points and help others
