GETTING AN ERROR MESSAGE SAYING THAT APPLICATIONS ARE BEING CLOSED DUE TO OVERHEATING.
    Problem Solver:
  • 16 Answers
Is this a laptop?
if so there is a good possibility that you may be blocking the air vents where the hot air is pulled off the cpu. also the heat sink on the cpu could be dirty inside the computer . If so it needs to be cleaned. in many cases venting of air is blocked when placed on a soft surface or lap
Posted on May 17, 2017
SOURCE: Problem with sony ericsson w580
I have the EXACT same problem after downloading a few songs. Did you experience this problem? Now I suggest you check an AT&T store and ask about the phone there (EVEN IF YOU DON'T HAVE AN AT&T PLAN). Tell them about it and ask if they know about this. Since this is occuring to me you can send a complaint to Sony Ericsson about this as well. Notice that you may be missing ALL your applications in that area...It's a strange phone. Good sound quality but probably more buggy than the CECT Hiphone!
Posted on Sep 10, 2008
SOURCE: Wireless WLAN
I have been working with Dell on this problem for quite some time. They tried replacing drivers, uninstalling and re-installing the card, replacing the card with a new one, etc, etc. Nothing worked. Sooner or later the error came back. Their last "fix" was to suggest that I restore the system to factory default condition and start all over again. I refused to do this. I had spent over 8 months adding software, tweaking it and windows, etc. They basically threw up their hands and gave up.
The Dell tech who replaced the card tried the solution noted here and "supposedly" it was fixed. A few weeks later the error came back.
So... I still don't have a fix for this problem.
If anyone finds one please let me know.
I'll check back here periodically.
Thanx,
Randy
Posted on Sep 19, 2008
  • 54 Answers
SOURCE: I keep having an error come up saying Messaging:
clear your browser cache as well
set your messages in messaging - options- settings - other to 999 and e memory.
restore factory settings *#7780# default code is 12345 that might just might help you a bit and turn off and on your phone when you do all these things see if it helps any.
“Memory Full…Close some applications and try again” is a normal
message that usually comes on Nokia N70. It showed the memory used in the phone doesn’t have space anymore. But if the message still appears although the user already closed some applications it can be theproblem.
Someone who experience in this memory full problem said, an error message of memory full like above is appears each time he’s opened the
Camera. It also happens for a few times when he’s trying to open
messages, Gallery, or other applications. And then it will force to restart the phone.
Seems like it’s a RAM problem and might there are some applications unable to close completely. If your Nokia N70 phone has gone a start
menu button you can try to hold it down. This way will show you
everything that you have open and they can be closed easily so that
you can continue to take your photos.
So if it can resolve the problem you can reset/format by pressing *#7370#
Posted on Oct 30, 2009
Testimonial: "Kind of helpful. I have to enter some code when i do the reset and i have no idea what the code is so its not working. Thanks though"
SOURCE: After clicking print to PDF a schedule, Suretrak
Closed Sure Track. License is in use… discovered lock file in c:\programfiles\sure trak\~PVW~.loc Lock would not delete Stopped pervasive engine. Lock disappeared Restart App. Prints OK.
Posted on Apr 02, 2010
SOURCE: agfa snapscan e20, winXP unexpected error, application will clos
This means that in the save path there are some not supported symbols. Try saving in c:\ or d:\. This helped me.
Posted on Feb 14, 2011
Updater has stopped working ... error message pop up
turn it off in startup .
clik your start run
type msconfig
look in top right for startups
unchek
SoftwareUpdater.exe apply close restart system
Aug 03, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Microboard error code 306
The 306 Error Code is generated when any corresponding process or operation could not be completed successfully by the application.
error 306 may prevent the user from performing the required action or may the application will close unconditionally.
Technical (Deep) Description of Error Code 306:
This is a full Description of ERROR 306:
ERROR 306: MCIERR_DEVICE_NOT_INSTALLED.This error is due to .The default facility code
ERROR 306: EVENT_APPMGMT_UPGRADE_COMPLETE.This error is due to Application %1 from policy %2 successfully upgraded application %3 from policy %4..The default facility code
ERROR 306: SQL_306_severity_16.This error is due to The text ntext and image data types cannot be compared or sorted except when using IS NULL or LIKE operator..The default facility code
ERROR 306: ERROR_SECURITY_STREAM_IS_INCONSISTENT.This error is due to The security stream for the given volume is in an inconsistent state. Please run CHKDSK on the volume..The default facility code
ERROR 306: CO_E_LOOKUPACCNAMEFAILED.This error is due to The system function LookupAccountName failed .The source of the error code is an RPC subsystem.
ERROR 306: STATUS_LOGON_SERVER_CONFLICT.This error is due to The Netlogon service cannot start because another Netlogon service running in the domain conflicts with the specified role. .The default facility code
Fixing Error 306 manually is a difficult process and it is not recommend unless you are an expert in this field.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Jul 13, 2012 | MicroBoards CFD-USB-15 1 Read,15-Port USB...
While running a program, an error message which says "protected memory violation" was displayed and the calculator stuck and i can't do anything.i cannot close,reset it nothing.can you help...
Application functions cannot be called from within the application. If you try to call a function using the
application's problem-entry dialog boxes, the error message, Protected memory violation, will appear.
Exit and re-enter the application to ensure normal operation.
Jun 12, 2011 | Texas Instruments TI-89 Calculator
The application starts "listening" and
Easiest way to deal with that is to close app, open multitasking bar hold on SoundHound icon then tap on red badge. Go ahead to App Store and redownload it again. By the way: is your telephone Jailbroken ? If yes, I suggest you to get rid of it, due to some instability in system.
May 15, 2011 | Melodis Corporation SoundHound
Hiii first of all i waant to thank you for the tips/solutions. I am using samsung jet. when ever i open any application , i get a error message "not enough resources close some...
May be there are some open applications in the background.Close it all if unnecessary, and try opening the desired application. Free up phone memory by moving data to a memory card.
Mar 04, 2011 | Samsung Jet S8000 Cell Phone
It won't come on it just says Jvm 513 reset
Thank you for using Fixya1
Based on www.blackberry.com the error message you are getting is due to typing incorrect password for a couple of times (10 or more).All of the data and applications on the BlackBerry smartphone have been deleted.
The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone. For instructions, click HERE
Note: Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader.
May 24, 2010 | AT&T Blackberry Curve 8300 Smartphone
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
I keep having an error come up saying Messaging: Memory full close some applications. I have also had an error saying General: Memory full close some applications. I have no applications open can you...
Oct 30, 2009 | Nokia N97 Cell Phone
Sony Ericsson W350i camera not working
sony ericsson camare problem...when i will start camare ,,display message 0 hold ,,another application running ,,close to start
Jun 27, 2009 | Sony Ericsson W350i Cell Phone
ERROR MESSAGE: "Checksum error."
The Checksum error usually indicates a data transmission issue. This may be due to a loose connection, bad wiring, electrical interference (cross-talk), a physical problem with the device itself, or a conflict caused by another software program. * Make sure that the cable attaching the camera to the computer is secure at both ends. * Close down all of the computer's other applications before attempting to download. 1. Press the CTRL, ALT and DELETE keys simultaneously. This will bring up the Close Program Window. 2. Highlight the program that you want to close and select END TASK. The Close Program window closes only one program at a time, so you will have to repeat these steps for each program that you want to close. NOTE: The SYSTRAY and EXPLORER programs should be allowed to run. Do not select End Task for these programs. You will also want to leave any necessary programs running, such as those controlling a wireless mouse or keyboard.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
