Question about Bissell Vacuums
Questions asked for electrical consumer products
Applying for a job with Bissell
Product won't turn on. Had been left to charge overnight but still won't power on.
Maybe battery load failure. Contact Bissell Consumer Care: 1-800-237-7691. They can assist in getting a new battery.
Aug 16, 2015 | Bissell SpotLifter 2X-Handheld Carpet...
Lift Off. Why doesn't the on-off button stay on?
Depending on age and use the switch may be broken. Contact the Bissell Consumer Care at 1-800-237-7691 to order a new switch. Ensure you ask directions on how to remove and replace it. Hope that helps.
Aug 01, 2015 | Bissell Vacuums
How does the bis sell preheat extract the water
Your question isn't clear but it sounds like you need to contact Bissell Consumer Care at 1-800-237-7691
Jul 01, 2014 | Bissell 7901-1 ProHeat Scotchgard Upright...
Clean bissell spot bot brush
NONE of these answers apply to the question! The asker referred to the Bissell SPOTBOT, which doesn't have a push handle. I'd like to know how to remove the brush myself. I know how to remove the components but haven't been able to figure out how to remove the mechanism.
Mar 12, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
How can i find usser instructions
http://www.bissell.com/images/UserGuides/7901_1008.pdf
www.bissell.com
When i use your numbers there is no match but this should get what you need.
Mar 20, 2011 | Bissell 8910 ProHeat Clear View Upright...
Wont **** up water
Go to bissell.com go unger frq.asked questions. Also check your belt
Jul 23, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Mar 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I am looking online for a replacement motor for my Bissell ProLite 3560-2 upright vacuum. I have found two different part numbers and do not know how to determine which is the correct one. 2146060 or...
The bissell website has a user manual http://www.bissell.com/images/UserGuides/prolite.pdf and it states the motor is warranteed as follows...Note the section pertaining to the motor... that may apply to you...
Warranty
This warranty gives you specific legal rights, and you may also have other rights which may vary from state to state. If you
need additional instruction regarding this warranty or have questions regarding what it may cover, please contact BISSELL
Consumer Services by E-mail, telephone, or regular mail as described below.
Full Three-Year Warranty on BISSELL ProLite Vacuum Parts
BISSELL Homecare, Inc., upon receipt of the product, will repair (with new or remanufactured components), or if repair is not
possible after a reasonable number of attempts, either replace (with new or remanufactured product) your ProLite Vacuum, or
refund the purchase price, which ever you prefer, free of charge, for THREE YEARS from the date of purchase– any defective
or malfunctioning part.
This warranty applies to product used for personal, and not commercial or rental service. This warranty does not apply to routine
maintenance components such as filters, bags, or brushes. Damage or malfunction caused by negligence, abuse,
neglect, unauthorized repair, or any other use not in accordance with the User’s Guide is not covered. See information below
on “How to obtain service for Your BISSELL product for Service”.
Limited Warranty 0n BISSELL ProLite Vacuum Motor Housing
Subject to the *EXCEPTIONS AND EXCLUSIONS identified below, BISSELL will repair or replace, (with new or remanufactured
components or product) at BISSELL’s option, free of charge, from date of purchase by the original purchaser, for:
Five (5) Years – a defective or malfunctioning Motor.
Ten (10) Years – a defective or malfunctioning Motor Housing.
*EXCEPTIONS AND EXCLUSIONS FROM THE TERMS OF THE LIMITED WARRANTY
THIS WARRANTY IS EXCLUSIVE AND IN LIEU OF ANY OTHER WARRANTIES EITHER ORAL OR WRITTEN ON
THE BISSELL PROLITE VACUUM MOTOR AND HOUSING. ANY IMPLIED WARRANTIES WHICH MAY ARISE BY
OPERATION OF LAW, INCLUDING THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
PARTICULAR PURPOSE, ARE LIMITED TO THE THREE-YEAR DURATION FROM THE DATE OF PURCHASE AS
DESCRIBED ABOVE.
Some States do not allow limitations on how long an implied warranty lasts, so the above limitation may not apply to you
If your BISSELL product should require service:
Call BISSELL Consumer Service at 1-800-237-7691 and we will give you the name and address of an authorized
BISSELL Service Center in your area. If there is not an authorized BISSELL Service Center in your area, one of our
Service Representatives will be happy to assist you. You can also visit the BISSELL website - www.bissell.com to
locate a Service Center near you.
For information about repairs or replacement parts, or questions about your warranty, call:
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 10 p.m. ET
Saturday 9 a.m. — 8 p.m. ET
Or visit our website @ www.bissell.com
When contacting BISSELL, have model number of unit available.
Please record your Model Number: ___________________
Please record your Purchase Date: ___________________
NOTE: Please keep your original sales receipt. It is your warranty.
It is suggested you staple your original sales receipt to the
front of this guide.
Filtrete and 3M are registered trademarks of 3M Co.
Warranty
©2004 BISSELL Homecare, Inc
Grand Rapids, Michigan
All rights reserved. Printed in USA.
Part Number 310-6004
Rev 4/04
Visit our website at:
www.bissell.com
ug310-6004_3561_404.indd 12 4/29/04 8:29:16 AM
Sep 21, 2008 | Bissell Vacuums
Bissell 2X Proheat 9200 - uses lots of cleaner.
May be that the cap and valves on the bottom of the tank is not shutting like it should and letting too much to come out. You may have to replace them.
Mar 10, 2008 | Vacuums
Over heated
In the handle are a heater, transmission and a circuit board. If you have smoke come out and now it doesn't work, I would suspect the circuit board of being bad. If this is less then 2 years old, then it is still under warranty.
IF YOUR BISSELL PRODUCT SHOULD REQUIRE SERVICE:
Call BISSELL Consumer Services at the number below or visit the BISSELL Website - www.bissell.com to locate a BISSELL Authorized Service Center in your area.
Website or E-mail: www.bissell.com
Select "E-mail BISSELL"
OR Call:
(800) 237-7691
Monday - Friday 8 am - 10 pm ET
Saturday 9 am - 8 pm ET
Nov 24, 2007 | Bissell 7950 ProHeat Upright Wet/Dry...
Vacuums Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
