Question about Lands Phones
Linking a handset to a 1484 series phone - Lands Phones
Need a manual for Uniden DXAI8580-2 5.8 and DCX160 6.0
This is the link for the manual for the DXAI8580
http://www.telecomuserguides.com/manuals/filesupload/Uniden/5_8GHz/DXAI8580-2om.pdf
The DCX160 is the part number for the accessory handset used with Models D1660 and D1680 and a few others models. The handset used for these series are all interchangeable and has the same keypad function. You can reference the information for the DCX160 using the handset for D1660 Following is the link for the D1660
Apr 20, 2017 | Uniden Lands Phones
How to I get a security code for my uniden sect 6 D 1484 cordless phone that I bought at a garage sale?
The remote access (security) code is chosen via the handset:
press [menu]
scroll to "Ans. Setup" press [select]
scroll to "Security Code" press [select]
enter the two-digit code of your choice
press [select] ( chirps ) press [END]
Remote *management* of the answering machine is
further described in the owners' manual. To obtain
a replacement manual, you'll need the precise model
number of your phone: this is found on a small sticker
underneath the battery inside the handset. Take this
model number (eg, D1484) to www.manualslib.com
and you can download a free copy of the manual.
Nov 11, 2015 | Uniden Lands Phones
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
Deregister used panasonic handset without base
On another working handset do the following;
Menu #131
Scroll and select the handset you want to deregister
Confirm you want to deregister
"Deregister" screen will display and handset will be deregistered
Feb 15, 2012 | Panasonic KX-TGA650B 5.8GHz 2 Line...
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
How do i deregester my phone
Press and hold END and # for more than five seconds. Select "Deregister HS".
Select the handset which you are operating, and then press MENU/SELECT.
The phone will ask you to confirm the deregistration. Select Yes. The selected handset will clear its registration information only from the base it is currently connected to, and then delete the link to the base from its own memory.
If you need a manual, you can download one at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1560om.pdf
Sep 19, 2011 | Uniden DECT1560 Series Phone
Can't listen to my voicmail
Click on a left side link of download manuels. ------------ 40000 series DS4122-4 ------------ 50000 series cs5121-4 ------------ i6785 English Not sure what series you have, but take a look at these manuels. found here :http://www.vtechphones.com/vtechui/support/manual_list.cfm#214 if not anyof these listed- there are many others to view and I know you'll find right instructions here!! Let me know if this helped.--Stevie ----------------------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID ------------------------------- 5.8 GHz digital Four Handset Cordless Phone System with Digital Answering System and Caller ID --------------------- 5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID i6785 - Spanish 5.8 GHz Digital four handset telephone system with digital answering system english i6786 5.8 GHz digital four handset cordless phone system with caller ID and digital answering device i6786 - Spanish 5.8 GHz digital four handset cordless phone system with caller ID & digital answering system
Feb 14, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
Mitel 5220 Electronic hook Switch?
The only electronic hook switch that I know about is on the 5330/5340 series phones, with the cordless headset from Mitel.
Here is a link to see what they look like... I have several installed at sites and the customers love them, no more handset lifters are involved. http://www.mitel.com/DocController?documentId=25305
Jul 24, 2009 | Mitel 5220 IP Phone
Unable to register handset TWX955 Series
I have a TRU9585 Base.
On the BASE press menu/select, scroll down to register handset using the button to the right of the display, and press select. The LED on the base will flash quickly.
Now pick up the TWX955 handset (the one that won't register), and press and hold # until it registers.
Worked for me.
Mar 15, 2009 | Uniden TRU9585-4 Quad Cordless Phone
Phone problem
I lost my manual for my GE 5.8 cordless gigahertz phone, and don't know how to program numbers in it. Can you please help me out?
Nov 30, 2007 | GE 25952 Cordless Phone
Lands Phones Logo
26 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
