Optics Logo
J
James Ruch Posted on May 16, 2017
I have a S&W New Depature .32 Concealed hammer top break 3inch barrel nickel finish revolver . Ser #22792 followed by a star. Looking for the year it was made.
3 Related Answers
IsaacCarlson
  • 79 Answers
  • Posted on Jan 08, 2011
SOURCE: Hi, I received a Crosman
Hit the top of the barrel with your hand. Don't be afraid to give it a good whack.
Mister Danger
  • 5631 Answers
  • Posted on May 28, 2015
SOURCE: Manufacture Date of Iver Johnson Arms, Inc. .32 S&W Top Break Revolver
Take your gun to a firearms store. They know ALL about the theme
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Mar 21, 2017
SOURCE: I have an iver Johnson 12 gauge shotgun single brake barrel with hammer ser. no.14976B Trying to find year and what the value would be.
Sorry we are not an appraisal service or a source of info for guns. Please contact a local gun shop.
32-20 Revolver ser.# 120328 what year and what ammo
Who made this? You need a mfr name to get started.
Jul 09, 2018 • Firearms
Where can I get parts for hr top break 32 cal revolver ser no 87358
Although they won't allow gun sales, there are some parts on Ebay, and there are many gun sales sites that you can research, such as gunbroker.com and gunsinternational.com.
Sep 08, 2017 • Optics
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 • Firearms
1helpful
Trying to find year and manufacturer of a single shot 410 breakover shotgun. Serial number L5972 has serated area by notched site.
iver johnson single barrel champion shotguns with a single letter suffix to the serial number were manufactured between 1920 and 1929. it seem that most of the 410 were used quite a bit and very few are in excellent condition. the original finish was an oil finished stock, browned barrel and case hardened frame.
CHAMPION MODEL 36--------------------------------1909-1922
Single barrel; rebounding center mounted hammer; top lever operated break open design; gauges: 12, 16, and 20; barrel length: 28, 30, and 32 inches (features barrel and lug forged in one piece) bored full chock only; American black Walnut but* stock and fore-end; automatic extractors; weight 6¾ pounds; overall length with 30 inch barrel 45 inches; case hardened receiver (nickel available as option), browned barrel; automatic ejectors extra cost option; .410 bore, 24 and 28 gauges offered in 1913; 24 gauge dropped 1928; all gauges except 12 dropped after 1941; name changed to Champion single Barrel in 1917.
CHAMPION SINGLE BARREL---------------------------1923-1978
This is the same gun as the earlier Model 36 champion except that the smaller gauges are now built on the same frame as the large gagues. See above picture for specifications. The exact year production stopped has not yet been determined. Some of these single barrel shotguns have been seen with Canadian marking, these were most likely shipped to Canada and then marked as there is no evidence that Iver Johnson's Arms & Cycle Works ever had a manufacturing factory in Canada
Jun 01, 2015 • Optics
Top The Optics Experts
NOEL
NOEL
vince
Are you a The Optic Expert? Answer questions, earn points and help others
