Question about Coffee Makers & Espresso Machines
I have just bought an EC1341 coffee machine. I am trying to set it up and no water is coming through he coffee filter. Little bit of steam and that is all. I have the water down properly
SOURCE: Water leakage- V'spresso machine
I had the same problem. The water was coming from the front door switch inside top right. I followed the water and turns out the part that needed to be replaced was the steam valve body. #48. http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg and link http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg after I changed it the pool of water under the machine stopped. I hope this helps.
Posted on Mar 10, 2009
EsWorld
  • 1618 Answers
SOURCE: My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Posted on Jun 06, 2009
  • 81 Answers
SOURCE: Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Posted on Feb 03, 2010
  • 11 Answers
SOURCE: coffee machine blocked
it could be grind stuck in the (yes the, as in the only) hole in the filter cup. remove the filter cup from the cup holder (the thing with the black handle) and use the tiny pin in the little brown tool to push out whatever is in there. you may have used to fine a grind or stuffed the filter cup too much. careful, that is how you break the plastic filter holder ring.
for calcifying, i just use plain white vinegar. i put it in straight into the clear water holder, about 3/4 cup, then i run it throuhg a bit, let it sit 5 min, run it through a bit, let it sit 30 min to an hour. depending on the day, i repeat a few times, rinse with clean water. i do this about every 2 months.
Posted on Aug 13, 2010
  • 1089 Answers
SOURCE: Our Saeco Magix Deluxe (old
Hi
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Posted on Oct 23, 2010
My maxim steam coffee machine will boil the water and froth the milk, but for some reason will no longer allow water to feed through to make the expresso - any ideas?
First things first, try a descaling solution, especially if you live where there's hard water. Sometimes minerals can crust up the brewing portion of the internal tubing. The steam part still works because it essentially leaves the limescal in the pot, channeling only steam through the steaming wand. Dump out any water in the reservoir, then put in a mix of half filtered or distilled water, and white vinegar. Run it through, setting the switch for brew mode only. Once you see it coming out of the filter holder, turn the machine off. Let sit for an hour or two, then run the same sequence again, shutting it off the moment you see the water/vineger mix coming out. Once again, let sit a while, then on the third cycle, let it run all of the vinegar solution through. Let cool, and rinse the reservoir with water, (put in water, swirl the machine around, then upend it to dump the water out.) then run the full reservoir of distilled wather through, repeating if necessary, to clear out the vinegar.
If that doesn't work, or if the vinegar solution never comes through, not even in a trickle, then there are other issues. Here's how to troubleshoot them.
The next steps will need to be done with some caution, as it may splash or shoot steam and/or boiling water out from the side of the porta filter holder!
Step 1...Remove the filter, and run it without coffee or filter in it. Do this from a few feet away or with something between you and the brew head of the machine, as it may cause hot water to spray with a fair amount of force!
Does the water come through the filter holder? If it does..
Step 2. Run it with the empty filter. If it the water doesn't come through with filter in place, then your filter is clogged, and you'll need to take a pin and clear the holes in it. If it does, then you're grinding your coffee too finely, or tamping it down to hard.
If the water doesn't come through with just the empty filter holder, then you've most likely got a valve (A.k.a. Brew/steam switch) problem. Frankly, it's easier to buy a new machine than replace that valve, especially if it's the automatic variety that switches you to steam whenever it's finished it's brew cycle.
If you've got one with the manual brew/steam switch valves, you can pull the knob off and see if it the stem turns with a needle nose pliers...{{NOTE: DO NOT DO THIS IF THERE IS STEAM LEAKING AROUND THE KNOB! Steam leaking around this knob can indicate that the ceramic valve is compromised, and could cause live steam to shoot out of the place where the knob is!}} if it does turn as smoothly as usual, and the machine works, then you just need to repair the knob because it's gotten stripped out or is broken where it meets the valve stem.
Nov 08, 2017 | Coffee Makers & Espresso Machines
It shoots too much water coffee come out watery
try adding more coffee to the filter, or making the grind FINER or both
Mar 08, 2011 | Coffee Makers & Espresso Machines
Coffee machine blocked
Aug 03, 2010 | Breville ESP8XL Espresso Machine
We have just bought a secondhand baby Gaggia and we cant get the steam to come out the frother. It is an orange coloured machine .
Propably the steam pipe is blocked from dry milk. You can use a thin steel wire insert it in the pipe from bottom. If you manage to open it a little bit and start having steam then by boiling water and leave the steam pipe imerse in it it will melt the remaining dirt and by open the stem valve then the dirt will spoot out. If not then the valve is blocked or broken.
Jan 02, 2010 | Gaggia Baby Espresso Machine
Can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Feb 22, 2009 | Cuisinart EM-200 Espresso Machine
No steam
There is descaling and then there is descaling.
We have written a good article on how to descale saeco coffee machines which you may find useful.
Try a really heavy descale - use the recommended dosage of descale powder or solution in 3/4 the recommended quantity of water.
Run some coffee through the coffee side of your machine, then the water/steam side of your machine and then allow to sit for a good five monutes before repeating.
Do this until the solution no longer comes out with a greenish tinge and then flush both sides with fresh water.
Make you use on filtered water or an in tank filter in your machine.
If this doesnt work it's off to your saeco service center.
Paul from Coffee Shrine for Saeco Coffee Machines
Aug 20, 2008 | Saeco Classico Espresso Machine
Water is only coming out of the steam valve not the coffee maker part
I apologize if I offend you in saying this, but perhaps check the steam knob and make sure it is off, turned all the way away from you. If the knob is even a little bit engaged the water will bypass the brew group significantly.
Otherwise, your shower screen may be severely clogged, though I doubt this is the case if you have only made one cup of espresso. Give it a look though, and scrub it off with hot water and a grouphead brush--or a dedicated vegetable scrubber brush (my preference :)
May 15, 2008 | FrancisFrancis! X5 Espresso Machine
Salton Model # 17
I think I've figured my yard sale EX 80 out. First, the way I think it works... in the tightly sealed boiler the water is heated to boiling, it must have a pressure release valve that sends the water/steam through the coffee and into the carafe. So dangerously hot and under pressure. Before opening the big round cap at the top (reservoir) relieve pressure at the steam tube valve (right side)
Here's how I made my first batch:
When opening reservoir always turn unit off, let reservoir cool a little between batches or you may get a cloud of steam in your face when pouring in water, might not be good for the heating element to shock it with sudden drastic temperature changes either.
Cleaned by running a couple of jugs of water through, cold water (4 on the supplied jug) into the reservoir all parts installed. I read somewhere online (not specific to any machine) not lukewarm water, if it's online it must be true... right?
Put coffee into filter basket/basket holder, matching amount of water in reservoir, 2 or 4 (markings on filter and jug). Espresso coffee should be very finely ground
Install all covers and the coffee basket/filter basket, close steam tube valve, install carafe and turn on the machine. Should get blast of espresso after a couple of minutes.
The steam tube (operated by the valve) seems a little cheesy on first try but I'll get better with practice. There's no steam to the tube until the reservoir starts to send steam to the coffee, the coffee kinda restricts the steam enough to send it to the tube. I was thrown a little because I didn't get steam when I was cleaning the thing, but I think that was because there was no coffee to block the flow. So I opened the valve at the start of the brew, steamed the milk, closed the valve and then the steam blasts through the coffee, tasted good.
Great $1 find.
Hope this helps.
Apr 27, 2008 | Salton EX80 Espresso Machine
No hot water or steam
Well, I have little exposure to Saeco, but a lot to commercial coffee machines.
Saeco have a lot of custom made components, although these can be purchased, nothing is cheap! Neither is their repair service!
First, is the boiler heating?? If so:
No hot water/ no steam suggests a blockage. Assuming you can hear the pump working when attempting to do a coffee, you will probably find the water flowing back into the water tank via the relief valve. Of course, this valve itself could be the problem, or the pump failing to work through a blocked inlet filter or other problem.
Look now at the group head. Ever cleaned it? The filter and spray block should be removable, do so and clean them carefully. While you have them out, see whether water reaches the head by "making a coffee" into a cup placed under the head. BE CAREFUL OF SCALDING. If water now flows, cleaning the screen and spray block should restore operation.
Beyond that, it's inside the machine! There is a 3- way valve that operates when making a coffee. This can become clogged with coffee. There is another valve to open the steam.
If, like Saecos I have worked on, the boiler does both the hot water and the steam one at a time, look for problems BEFORE the boiler.
Hoe this helps a little....
Jan 19, 2008 | Saeco Vienna SuperAutomatica Coffee...
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
