Question about Zebra Eltron TLP 2844 Thermal Label Printer
Zebra TLP2844 Prints Centered and Half the Width
I have 2.25 x 1.25 tags. However, it looks like the printer is printing only half that width. It's also centering that half image. Therefore there is a centered half tag printing out. I've checked the paper size settings in the printer's preferences. Anybody have an idea? Thanks in advance.
  • Anonymous Sep 25, 2008
Create a word template document with the page size the same size as the label. Set the margins to 0 and fill the label up with text. This should make the printer print right the way over the bale.
Posted on Jan 27, 2008
Zebra label printer cutt off prints
In printer control panel menu check the print width of the label according to the size mean to say if you have 4 inch label the print width set to maximum value if print width set minimum then cutts off the print.
Codabar Pvt Limited Pakistan
Apr 13, 2014 | Zebra TLP 2824 Printer
Printing half label width
hold feed button and release during 5 blinking lights. printer will auto set the width. Press feed again once you want the desired width.
If it's actual printer issue, then you have to call service tech.
Sep 23, 2013 | Zebra ZP 450 Thermal Label Printer
Using MS Access, I am printing labels to a Zebra 110XiIII printer. The output truncates the label to 2" instead of the 3.5" I have the report page settings saved as. I have been through the setup...
First check printer. Change setting "Print Width" to maximum width, save. Switch off. Hold down pause key while switching on (untill all but power light turns off). the subsequent prints should print across the full width. If this is OK fault is with label format.
If you are using windows printer driver check settings there this can over ride printer settings. If using ZPL the problem is most likely in the label format.
Jul 05, 2011 | Zebra 110XIIII Thermal Label Printer
My zebra only prints the left half? I have tried calibrating, it does nothing. Can you help me out? Thanks
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Best way to check this is to take your tallest and widest label and print out a configuration label. This is done by turning off the priner, pressing the CANCEL key and holding while turning on the printer. Release the button when the calibrate led turns off. A config label will print and you can check the setting for PRINT WIDTH.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles the press down on the printhead and the pressure can be adjusted on each by turning the knob on top. Readjust the right side until printing returns across the label.
Hope that helps !
Apr 26, 2010 | Zebra Stripe S600 Thermal Label Printer
Half of the labels information is printing
I'm assuming you mean half is showing up as you go across the label. If that is the case and it's a very clear line where the print is cut off, then check the print width setting through the front panel of the printer. Press SETUP and look for setting called MAX WIDTH. It should be set to 104MM (4") which is the width of the print head. It is set to something smaller if the print is being cutoff.
If the print is fading away as you go across then that it is a print head balance issue. Look at the print head pressure dials on top of the print head assembly to make sure they are set evenly.
Hope that helps !
Apr 14, 2010 | Zebra Z4Mplus Label Printer
If the printing clearly stops, then the maximum width setting of the printer is not set to the full 4 inches (104mm) of the printhead. Go into the setup mode on the printer and look for the setting called PRINT WIDTH and make sure it's set to 104mm or close to that. If printing is only half way across the label, it's because the width is set to something less than 104mm.
if the print fades away off the label, that is due to an imbalance in the pressure across the printhead.
Hope that helps !
Feb 18, 2010 | Zebra Z4Mplus Label Printer
Just one of the double tags is printed on
I assume by double tags you mean 2 labels across the roll.
You need to tell your software that the roll is 2 across.
If using the software that comes with the printer, Zebra designer.
Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
Feb 10, 2010 | Zebra Eltron TLP 2844 Thermal Label...
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Zebra 105SL print only half of label
This can happen if your page size in your driver is not set to the actual label size. It can happen if you have old .dll driver files mixed with your mew driver installation.
This is what I would do:
Uninstall the driver completely - delete the icon in Printers and Faxes. Drop down the file menu there and choose server properties and remove the driver for all Zebra printers from the Drivers tab. Go into the LCD menu of the printer and load defaults. Go back into the LCD meny and look at the page width setting. Your printer has 300 dots per inch, so a 4 inch label would be 1200 dots wide.
Another thing to consider is that you may be trying to printer to a 300 dpi printer from a 203 dpi driver. Make sure that you choose 300dpi when you reinstall. This should work.... If not, repost with more details about your application and driver. I can assure you that this is not a printer problem unless half of your printhead has failed.... unlikely, but possible....
Jan 16, 2010 | Zebra 105Se Thermal Printer
Zebra LP 2844 direct thermal printer is only printing half the width of the label. Label dimensions appear correct in prefrences.
check the "unprintable areas" on the preference. it should be Zero. find the Zebra Setup Utility on , with that utility program, try to set the printer to the factory default
Jul 10, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra Eltron TLP 2844 Thermal Label Printer Logo
1,462 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
