Question about Sewing Machines
My machine keeps knotting up won't sew a straight line without snagging
  • Sewing Machines Master
  • 1,830 Answers
The tension is too tight.
Posted on May 16, 2017
Pfaff 7570 puckering & snagging fabric while sewing straight stitch.
Might try a brand new needle. The old needle may be damaged so it is snagging the fabric and possibly not penetrating the fabric cleanly.
Oct 05, 2017 | PfaFF Sewing Machines
Model 9600..thread keeps knotting up on bottom
Check the upper tension discs for lint: Raise the presser foot to open up the discs and blow or 'floss' between them. Any lint or thread in there will prevent them from giving the proper tension.
If that does not work then you may have a damaged hook and/or bobbin case that is snagging the thread. There are a few other reasons also, but you probably need to have it serviced to fix.
Feb 24, 2015 | Singer Sewing Machines
Toyota 8002 sewing machine
If the machine line won't run straight, then it needs to go back to the manufacturer, but if you find that you can't make it go straight, then slow down and watch the edge and keep it straight by judging the distance and keeping it the same. You will speed up with practise
Aug 14, 2014 | Toyota Sewing Machines
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
Kenmore sewing machine 16520
Bobbin case problems are common, and usually bobbin race parts are easy to find and not too expensive if you need to completely replace them. Otherwise I have successfully sanded down burrs on cases and races if that is what the thread is snagging on... ? Without having someone look at how it is snagging, it is hard to diagnose. Hope you figure it out!
May 01, 2014 | Sewing Machines
Trouble shooting
its the tensioner knob turn it a little bit till the stitch is back to the way its suppose\ed to be, don't turn the knob a lot ust a hair a little AT a time try the stitch each time you turn it to see if the stich is tight again. The knob has numbers on it you have to d this in straight stich setting
Apr 28, 2017 | Sew D'Lite Lightweight Portable Mechanical...
Blind hemmer is "frozen" won't move at all. What can I do?
on a normal sewing machine this usually means the threads are all snagged up in a knot in the bobbin case. Snip your threads, wriggle the fabric out, remove all snagged threads and rethread the machine. I don't know if this will work with your blind hemmer.
Apr 25, 2013 | Sewing Machines
Thread knotting
Your bobbin is not wound correctly.
Jun 11, 2012 | Brother Sewing Machines
My machine is a singer 2259 tradition my machine is making knots, i can sew two points and then it s totally locked aqnd won t work any more because it's full of knots
Machine threaded incorrectly. Insufficient tension on upper thread. Bobbin case spring broken. Lint clogging thread path. Bobbin wound incorrectly.
Jun 05, 2011 | Sewing Machines
I have a Euro-Pro 7500. I can't seem to sew a straight stictch without the thread binding up from the bottom of the material.
Do you mean the thread knots and loops up under or over the fabric? If so it sounds like you need to re-thread. You may have not put the thread into one of the tension wheels correctly. Keep the presser foot up when you do it.
Jan 25, 2011 | Euro-Pro 7500XH Mechanical Sewing Machine
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
