Question about Kenmore Microwave Ovens
I am try to microwave something on a Kenmore microwave # 721-62644200 and I don't know which buttons to push on the key pad to accomplish this setting
All is lost.......jump
Posted on May 16, 2017
Lg microwave is locked the key pad 2010 model
1st try unplugging it and plugging it back in.
2nd The key pads can appear to be locked when it's just pushing the right buttons that fixes it.
I have run into that more than once myself.
I'm clever and it took me a while to find the right one.
It usually had something to do with setting the clock.
Try pushing each one from left to right & top to bottom just like you read. One of them probably will give you options.
Not likely but it is possible it could be 2 buttons at the same time but I've never run into that.
Mar 04, 2018 | LG Microwave Ovens
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
Aug 18, 2017 | Kenmore Microwave Ovens
How do I fix the key pad of a Kenmore microwave model 401.80084700?
I don't know of anyway to repair the keypad. Usually replacement (of the keypad/control console) is the only option. But you might want to remove the ribbon cable that connects the keypad to the control board behind it, clean it with a degreaser (like Fantastic or 409), dry it, and re-insert it, and then try again. (Remember to unplug the microwave oven first before you try that!)
Jul 07, 2014 | Kenmore Microwave Ovens
Digital button on kenmore microwave does not respond when pressed could this be a fuse or is key pad gone
Considering the problems you are having it would be cheaper to replace the microwave oven.
May 22, 2012 | Kenmore Microwave Ovens
Several buttons on key pad of microwave are not working
Steam got into key pay. Sometimes it will dry out. Take key pad apart and try to dry with a hair dryer, not to hot, you just want to blow condensation out of it. If this does not work, key pad needs to be replaced. The problem is they cost as much as a new microwave.
Sep 27, 2010 | Kenmore Microwave Ovens
The key pad doesnt work, had it less than a year. Unplugged and then plugged it back in and it tells me to set the clock but when i push the buttons nothing happens. The key pad isnt locked already tried...
The panel may have a short or need to be tested for replacement. You should try and leave unplugged for 8 hours so power supply can fully drain power and reset microwave
Aug 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I am trying to set the kitchen timer on my older spacemaker microwave for 2 hours and am unable to do so ... Am I trying to do something impossible?
The first step is to set the clock. To do this, push clock, set the time using the key pad and then PUSH clock a second time.
Once that is done you can set the timer by pushing timer, putting in the number of minutes you want and pushing start.
Jun 07, 2009 | GE Spacemaker Over-the-Range Microwave
Key Pad displays Locked
My microwave has a child lock on it.To set it all I need to do is press the start button for 4-5 second to lock and unlock. It may be something triggered it. It might be a quick fix until you find out what is causing it.
Sep 17, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
