What happens when you e52853 ribbon is bad - Televison & Video
I have a P5215 Printronix printer and it is not printing some of the columns. The tech cleans it however, after a while, it happens again. He says we need to use printronix ribbons. Is that true?
Yes the aftermarket ribbons are re-inked ribbons and are bad for the frets. If your tech cleaned the frets with an abrasive tool or chemical other than alcohol then he removed the protective film and the frets are bad.
Aug 29, 2014 | Printronix Line Matrix P5210 Printer
Lines on screen only does have sound
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken..
I hope this will help in solving the problem....
Jun 26, 2011 | Proview Televison & Video
Vertical stripes all across screen
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken .
Good luck in solving the problem...
Jun 23, 2011 | Televison & Video
There are constantly white horizontal lines going across the screen
Good luck.
Jun 22, 2011 | Televison & Video
Washed out picture with visible retrace lines
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken Good luck.
Jun 14, 2011 | Televison & Video
Sony kv 21jdr1 prblem no raster only tracing line appear audio ok.
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken ..
I hope this helpout......
Jun 09, 2011 | Televison & Video
My samsung screen is white but it works ive tried everything, this hbas happen before screen going white and the battery had to be without juice to come back. it works but ithe screeen is white
hi, the main reason the screen turns whits is due to the thin ribbon that sends the data from the circuit board to the screen being damaged what happens is that the thin copper wires that are inside the ribbon ware and then break causing a short to the screen and this is what turns the screen white. this happens on most flip and slide phones as the ribbon moves when you slide or flip the phone so over time it becomes brittle and you lose the connection and this turns the screen white.
sometimes it will right itself if you open and close the phone a couple of times but this wont be a long term fix how ever it may be that bad that this will no longer work, its not expensive to get this ribbon replaced but taking you phone to a small phone shop would be your cheapest option.
May 14, 2010 | Sony Ericsson K800i Cellular Phone
DTC550 Fargo printer it says out of ribbon with new installed
Check to see if the RFID (green ring) from the old ribbon has come off and is stuck near the reader (located behind the green stem). I've seen that happen. I've also see some bad RFID rings. If that happens they should have a warranty from Fargo.
onlineidtech
Mar 19, 2010 | Fargo DTC550 Thermal Card Printer
Vertical line on my notebook lcd
Be sure that the LCD display drivers are up to date, if so, reboot system, if you see the vertical line on your display during the boot up process you have a hardware failure.
possible failures include:
LCD panel going bad
Inverter board going bad
Broken trace on the LCD connection ribbon from the graphics card to the LCD
Wrong type / speed / size of memory (i had this happen to me)
Graphics card begining to go bad.
Loose connections may also cause this, make sure the LCD's connection ribbon / wires are firmly connected.
May 30, 2009 | Acer Computers & Internet
Black band running from top to bottom of screen
this will need to go into the shop to get one of the video processing boards replaced that controls that part of the screen , this will happen when it gets to hot inside the set ,( thermal break down)
electech
Oct 31, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
