Question about Inverter Heating & Cooling
What ee means displayed on kolin inverter - Inverter Heating & Cooling
4 Suggested Answers
  • 2501 Answers
SOURCE: My Ironman has EE:EE on the display, The Chrono
I doubt if your watch is faulty. If you read your instructions I would expect you to be able to empty the memory.
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Posted on Feb 16, 2011
  • 739 Answers
SOURCE: Displaying "EE" Code. Does not run.
the best suggestion is to contact the manufacturer at: (877)337-3639.
Posted on Jun 19, 2014
sloooo44
  • 235 Answers
SOURCE: My kolin inverter type aircon wall mounted stopped working, the led display indicated E1. What does this mean?
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
Posted on Aug 09, 2016
Kolin inverter window type aircon shut down with FO code
when you post the same question more than once in a few hours most here tend to ignore them. once is enough. when someone who knows the answer comes on maybe youll get lucky.
Jan 28, 2018 | Inverter Heating & Cooling
Kolin error code E1 inverter 1hp wall mounted
What do you need to know, how to fix the error? If you need more questions for your AC Repair needs, check us out online.
Jul 12, 2017 | Inverter Heating & Cooling
E1 error code kolin inverter
Do want to know what the error means? Do you want to know how to fix it? If you need more questions for your Air Conditioning Repair needs, check us out online.
Aug 09, 2016 | Inverter Heating & Cooling
My kolin 2.0 hp inverter series what does mean by E5 displayd code
Hi i am aircon tech, the problem of e5 is fan capacitor & relay connected the fan motor.
Jan 19, 2015 | Inverter Heating & Cooling
Jun 19, 2014 | Haier CPN10XCJ Air Conditioner
Panasonic CWXC203EU the unit is flashing error code EE and only when you unplug it shuts off the control do not work blows s a littlle cold air but after a shor time it shuts off
Hi.
EE means energy efficiency. hen EE is displayed there can be a defective thermistor or insufficient ventilation.
The following works on some A/C system: "When EE is displayed, press "energy save" and "zone control" simultaneously for about 5 secs"
Try also testing the system in auto mode, check ventilation and if possible test thermistor by reading impedance with a multimeter.
If when EE is displayed the unit also becomes non-responsive and does not turn off, then the problem may also be a defective controller board. Other parts, included the ones mentioned before, must be tested before replacing the control module.
Regards.
Ginko
Aug 11, 2011 | Heating & Cooling
My LCD screen went of but there still sounds coming out
you have to check the back light off your lcd replace the inverter or capacitor in the power module
Jul 16, 2009 | Olevia Kolin DLT2711M 27 in. LCD...
Inputing Scientific Numbers
If you mean using the "EE" key it's straightforward.
To enter scientific numbers, enter the number, then press EE, then the exponent value. The TI-30XA will stay in scientific display until you "clear" or turn it off. It will also switch to scientific notation if you multiply big numbers that exceed the display.
E.g. Input 3, EE, 10, X, 3, EE, 10, =, gives you the answer 9 times 10 to the power 20. Press the "square root" key and you will get back 3 times 10 to the power 10.
You can mix entries too, e.g. 3, EE, 10, X, 2, =, gives you 6 times 10 the power 10....
Nov 29, 2008 | Texas Instruments TI-30XA Calculator
Heating & Cooling Logo
94 people viewed this question
Top Inverter Heating & Cooling Experts
MightyMikeJr
jeff5may32
Are you an Inverter Heating and Cooling Expert? Answer questions, earn points and help others
